paci87
Alt skrevet av paci87
  1. Part 18. http://realoem.com/bmw/showparts.do?mod ... g=11&fg=40
  2. Hi! The fuse for seat without memory is in the engine bay, next to the engine ecu, the car's right side. The fuse number is 15. You can try to change your instrument cluster with an E38 or E39 cluster to see if it changes.
  3. You can find a DIY here: http://bmwcoders.com/forum/bmw-gt1-ops- ... matic-839/ or you can buy it here: http://www.ebay.com/itm/BMW-INPA-Ediaba ... 1115011595 The Inpa is not too difficult to get, if you have the interface, just PM me.
  4. Hi! Turbo actuator valve can do this problem. If you need diagnostic than just PM me
  5. Hi! Reprograming the gearbox ecu, or the whole car could probably fix it for you.
  6. Hi! Which year is your E36? Usually INPA cable is not working with those, you need ADS interface I think.
  7. http://realoem.com/bmw/showparts.do?mod ... g=13&fg=15 Hi! It must look like this, on the throttle valve. The throttle valve usually not wrong.
  8. Hi! It can be the Abs modul, especially if it's number end is 001. Solder problems can cause this if it stopps to work when it's hot. I would change it for a try.
  9. You have to register the battery change in E60/E61 with diagnostic, if don't, it can cause battery charging problems. You should check if the registry is correct in the car. (sorry for english)
