Gunnar Skrevet September 27, 2003 Share Skrevet September 27, 2003 New three-wheeler launched by BMW 07/23/2003 For the first time since the unveiling of the legendary Isetta in 1955, BMW is once again launching a head-turning three-wheeler. This time it's not a ground breaking new car, but an innovative scooter. Created by BMW Designworks USA, the SlideCarver is made of rugged and light forged aluminium. Tight cornering, excellent handling and supreme stopping power is achieved without compromising comfort and stability - just what you would expect from a BMW. The SlideCarver's board is made of fibre-glass reinforced polyamide and aluminium with high load-bearing strength. Exceptional handling is achieved using a double-joint swinging support component taken from the running gear of the E39 BMW 5-Series. This ensures that when steering, the board of the SlideCarver pivots in the direction of the turn, improving the rider's centre of balance. Handlebar mounted brake levers are linked to a finely adjustable hydraulic twin-disc brake system on its rear wheels. The brake cables are discreetly located within the tube of the handlebars giving a more streamlined appearance and protection from weather and scuffing. Front wheel suspension also provides greater ride comfort. The SlideCarver is easy to transport. It incorporates a patented one-handed folding mechanism, consisting of a folding joint at the base of a telescopic handle bar that connects to the board, allowing it to fold up and fit into the boot of a car. Unfolding in a matter of seconds, it requires no additional tools. The SlideCarver comes with high quality, maintenance free wheel bearings fitted as standard and low profile polyurethane tyres that even have wear indicators to show when new tyres need to be fitted. The two-part aluminium rim can be easily disassembled to allow the replacement of the tyre running surface. The SlideCarver is made exclusively for BMW and costs £465.00. It's available now, and can be ordered from any BMW dealer. SlideCarver dimensions: Length 77cm Width 50cm Height Approx 100cm (when steering) Wheel base 66cm Weight 12kg Se bildene her (Artikkel opprinnelig publisert 23. juli 2003) Lenke til kommentar Del på andre sider More sharing options...
Gunnar Skrevet September 27, 2003 Forfatter Share Skrevet September 27, 2003 New three-wheeler launched by BMW 07/23/2003 For the first time since the unveiling of the legendary Isetta in 1955, BMW is once again launching a head-turning three-wheeler. This time it's not a ground breaking new car, but an innovative scooter. Created by BMW Designworks USA, the SlideCarver is made of rugged and light forged aluminium. Tight cornering, excellent handling and supreme stopping power is achieved without compromising comfort and stability - just what you would expect from a BMW. The SlideCarver's board is made of fibre-glass reinforced polyamide and aluminium with high load-bearing strength. Exceptional handling is achieved using a double-joint swinging support component taken from the running gear of the E39 BMW 5-Series. This ensures that when steering, the board of the SlideCarver pivots in the direction of the turn, improving the rider's centre of balance. Handlebar mounted brake levers are linked to a finely adjustable hydraulic twin-disc brake system on its rear wheels. The brake cables are discreetly located within the tube of the handlebars giving a more streamlined appearance and protection from weather and scuffing. Front wheel suspension also provides greater ride comfort. The SlideCarver is easy to transport. It incorporates a patented one-handed folding mechanism, consisting of a folding joint at the base of a telescopic handle bar that connects to the board, allowing it to fold up and fit into the boot of a car. Unfolding in a matter of seconds, it requires no additional tools. The SlideCarver comes with high quality, maintenance free wheel bearings fitted as standard and low profile polyurethane tyres that even have wear indicators to show when new tyres need to be fitted. The two-part aluminium rim can be easily disassembled to allow the replacement of the tyre running surface. The SlideCarver is made exclusively for BMW and costs £465.00. It's available now, and can be ordered from any BMW dealer. SlideCarver dimensions: Length 77cm Width 50cm Height Approx 100cm (when steering) Wheel base 66cm Weight 12kg Se bildene her (Artikkel opprinnelig publisert 23. juli 2003) Lenke til kommentar Del på andre sider More sharing options...
Sandersen Skrevet Februar 16, 2007 Share Skrevet Februar 16, 2007 ey en slik vill jeg ha.. hvor kan man få kjøpt ? (bedre sent en aldri vell??) Lenke til kommentar Del på andre sider More sharing options...
|Andreas| Skrevet Februar 16, 2007 Share Skrevet Februar 16, 2007 Den var stilig Lenke til kommentar Del på andre sider More sharing options...
mAZE Skrevet Februar 16, 2007 Share Skrevet Februar 16, 2007 Tråd fra 2003 faktisk... Lenke til kommentar Del på andre sider More sharing options...
ingard Skrevet Februar 16, 2007 Share Skrevet Februar 16, 2007 HVordan fikk du hamret opp denne tråden? Hehe, regner med det der ble en flopp eller? Lenke til kommentar Del på andre sider More sharing options...
Sandersen Skrevet Februar 16, 2007 Share Skrevet Februar 16, 2007 Hehe så på ubesvarte innlegg og siste side Lenke til kommentar Del på andre sider More sharing options...
Schnellfahren Skrevet Februar 16, 2007 Share Skrevet Februar 16, 2007 Sykkelen var jo helt konge da! Lenke til kommentar Del på andre sider More sharing options...
