KTM 50 Senior Adventure '03 barnecrosser selges BILLIG!
Den råste minicrosseren for barn mellom 6-8 år. Må bort innen tirsdag 18 Juli! Selges da til høystbydende over 5000,- Kan være behjelpelig med levering på det sentrale Østland dersom det er behov for det.
Nypris: 19900,-
Sykkelen er i grei stand. Kjørt 30-40 timer. Service tatt på 20 timer.
Tekniske data:
Engine type Single cylinder, 2-stroke
Displacement 49 cc
Bore x stroke 39.5 x 40 mm (1.55 x 1.57")
Starter Kickstarter
Carburetor Dell'Orto PHVA 14 DS
Engine lubrication Mixture lubrication 1:60
Transmission lubrication 0,15 - 0,2 l Motorex ATF Super
Primary drive 16:57
Final drive 12:48
Cooling Air cooled
Clutch Centrifugal clutch (adjustable)
Ignition Seletra analogue
Frame Central double-cradle-type frame
Subframe Steel
Handlebar Aluminium Ø 22 mm (0.87")
Front suspension Marzocchi Ø 32 mm (1.26")
Rear suspension Paioli monoshock
Suspension travel front / rear 185 / 190 mm (7.28 / 7.48")
Front brake Drum brake Ø 160 mm (6.3")
Rear brake Drum brake Ø 90 mm (3.54")
Rims, front / rear 1.6 x 12"; 1.6 x 10" Aluminium
Tires, front / rear 2.50 x 10"; 2.50 x 10"
Chain 1/2 x 3/16" 104 R
Main silencer Aluminium
Steering head angle 66°
Wheel base 1030 mm (40.55")
Ground clearance (unloaded) 255 mm (10.04")
Seat height 650 / 675 mm (adjustable) (25.59 / 26.57")
Fuel capacity approx. 2 liters (0.53 gal)
Weight (no fuel) approx. 38.4 kg (84.67 lbs)
