E21 Racingbremseskiver
Her står det litt om og bygge om til H3.
bli kansje litt mye men det står det meste her :wink:
What it takes to transform a 320i into a Hartge H3:
First you need the Hartge emblem and the H-3 emblem and they are no longer available. You have to have them made and it costs about $100 per emblem as they are laser cut and computer coloured.
You need the front valance which is no longer available but perhaps one could be found used (in Europe?).
The correct rear spoiler is the FOHA unit which I tossed and replaced with a Hartge E-30 unit. Those can be found still.
The suspension has to be changed to the Hartge/Bilstein units. These units (with springs) ARE NOT AVAILABLE FROM BILSTIEN and are a Hartge specific item. They too can be found used in Europe. Bilstein of America will rebuild them for you although there is not a warranty on them; even when new, Bilstein would not warrantee them!
Hartge used rear disc brakes off from a 323i which you can pick up. They are stock.
The front brakes that Hartge offered are called Group II and essentially are Girling Volvo units that are modified a bit.
The large master cylinder from a 528 is used and dual brake lines are run to each front caliper.
You also need the ventilated rotors off from a 1977 320i.
Of course the metallic body side stripes are important. (Still available - see E21 page on this website - supply is limited)
The seats in a Hartge were the Recaro option that you can pick up from eBay.
Hartge has their own steering wheel that I have seen several times on eBay.
They used their own shift knob. (Still available - see ACCESSORIES page)
The two instruments (tach and speedo) have a Hartge emblem on them that can be made same as the exterior emblems. The tach face will need to be changed with a 323i face as your customer needs the red and green face. That is an easy swap. The correct tach face is only found on the 6 cylinder 323i.
Wheels need to be Hartge. Hartge originally used 15 inch BBS basket weave wheels. It was just a popular change to put the HARTGE E30 wheels on the E21 chassis when Hartge created the (11 spoke Design A) OZ wheel. One has to use the 15 inch wheels if one was going to install the special brake set. Hartge offered both a 14 and 15 inch Design A wheel - but it's wiser in this day and age to buy the larger ones if possible!
Incidentally, the front valence can be used with the American bumper but one should convert to the European "thin" bumper.
The rear side marker lights need to be removed and the holes filled in. Of course it goes with out saying, the gas gauge needs to be replaced with the "metric" unit.
The center and left side dash panels need to be exchanged with ones printed in German; you can find them in Europe and Maximillian can also get them for you.
The right mirror needs to be exchanged with the glass from the drivers side.
The under hood stress bar is a necessity. (still available - see E21 page on this website)
Those changes would get him a close replica.
Along with the cylinder head, there was included a performance cam made
http://www.auto-mark.com/e21%20h3%20details.html (1 of 9)04.09.2006 12:27:03
http://www.auto-mark.com/e21%20h3%20details.html (2 of 9)04.09.2006 12:27:03
to Hartge's grind. I do not know who created it for them or even the lift or duration.
Also included in the H-3 conversion was Hartge's special exhaust system. It was not stainless and I can vouch for the fact that it would rust out soon here in Michigan.
Of course he can go further with the mono wiper (hard to find but . . .), VIN tag, and a raft of other "little" items that Hartge offered. The silver trim that runs in the windshield channel and the rear window (this is the locking strip) needs to be changed to black; only the US models had the crummy silver trim. Maximillian can get the locking strip; it is the same as an E-30 and is readily available although a US dealer cannot get it as it was Europe only.
Inform your customer that he is going to have to pony up a ton of cash for this conversion . . . the parts and NOT plentiful and are not inexpensive to purchase and/or to have made.
Reg's comments on how to (try to) document the history of an early HARTGE E21:
First you have to realize that most Hartge conversions were done on the E21 by independent garages who purchased the Hartge "tuner" parts, with the main one being a BMW dealer in Aachen (Germany) that HARTGE originally associated with.
It was later and primarily to my understanding that Hartge did a lot of conversions on the 5 series in house. The E21 H3 (323i) was Hartge's first iteration of their special parts and a number of dealers would 'Hartgeize' an auto in-house, and Hartge also sold the parts individually.
So . . . the way to document an early auto is simply by the presence of all authentic Hartge parts on it.
The H3 designation consisted of engine head along with suspension
upgrades.
From there, an individual could add the header/exhaust system, gauges, mirrors, brakes, fuel tank, quick ratio steering, stripes, valve cover, etc. (see details above!)
Lastly, the official HARTGE VIN "tag" itself was/is approximately 1&1/2 x 3 inches and included the BMW VIN along with weight of the vehicle in KG and the front/rear weights. It is aluminum and riveted with two rivets under the hood and in a conspicuous place.
http://www.auto-mark.com/e21%20h3%20details.html (3 of 9)04.09.2006 12:27:03
HARTGE E21 H3 PARTS AND NUMBERS
Provided for reference only - unless specifcally noted, essentially all of these parts are "NLA" (no longer available)
ENGINE:
11110310 Hartge H3 cylinder head kit. 180 h.p. 0-60 in 7.2 seconds 11110311 Hartge cylinder head 11110312 Hartge/Shrick special camshaft 11110313 Special gasket set 18110310 Hartge exhaust 12220100 Special rpm limiter. 6800 max rpm
ENGINE OIL COOLING
11220316 Engine oil cooling system 11220317 13 row oil cooler 11220318 Thermostat flange 11220319 1000 mm oil pipe 11220320 1200 mm oil pipe
http://www.auto-mark.com/e21%20h3%20details.html (4 of 9)04.09.2006 12:27:03
HARTGE EXHAUST SYSTEM
18110310 Hartge exhaust system front to rear. 7% increase in performance. (10hp) 18220431 Manifold front, black 18220441 Manifold front, chrome 18220432 Manifold rear, black 18220442 Manifold rear, chrome 18110327 Connecting pipe, left front, black 18110319 Connecting pipe, left front, chrome 18110328 Connecting pipe, right front, black 18110320 Connecting pipe, right front, chrome 18110314 Presilencer 18110315 Connecting pipe, left rear 18110316 Connecting pipe, right reat 18110317 Rear silencer, left and/or right 18110318 Mounting kit, complete
BRAKE SYSTEM
34110100 H-3s special brake system. Group 2 high performance. Use with 15 inch
http://www.auto-mark.com/e21%20h3%20details.html (5 of 9)04.09.2006 12:27:03
wheels only.
34110101 Brake caliper, front left (4-piston caliper) with brake lining
34110102 Brake caliper, front right (4-piston caliper) with brake lining
34110103 Brake disc, 271 mm
34110104 Fittings
34110105 Brake lining for 4-piston caliper, front
34110310 Sport brake lining for standard brakes, front
34110320 Sport brake lining for standard brakes, rear
STEERING
32110320 Sport steering. Short steering reduction ratio (2.2:1), special steering rackwith pinion, only for autos without power steering
32440100 Hartge 4-spoke leather steering wheel, hand-sewn, 380 mm
SUSPENSION
31110320 Hartge Bilstein sport suspension. 35 mm lower 31110321 2 Bilstein shock absorbers, front 31110322 2 Hartge sport springs, front 33110323 2 Bilstein shock absorbers, rear 33110324 2 Hartge sport springs, rear
http://www.auto-mark.com/e21%20h3%20details.html (6 of 9)04.09.2006 12:27:03
31110330 Hartge Bilstein competition suspension 31110331 2 Hartge competition struts, front 31110332 2 Hartge competition struts, rear 31110334 4 Hartge sport springs 31110350 Hartge light alloy strut brace, front (still available - see
ACCESSORIES in HARTGE section)
33110351 Hartge light alloy strut brace, rear
MISCELLANEOUS
11220436 Hartge valve cover 25110001 Hartge wooden gear lever knob up to 1981 99490140 Hartge leather gear lever knob after 1981 (still available - see
16110300 Hartge extra fuel tank in aluminum, 35-litre 16110301 Boot mat for fuel tank 51220910 Hartge décor set, aluminium metallic (still available - see
51220920 Hartge décor set, anthracite metallic (still available - see
36110370 Splash guard, rear set 61110305 Hartge single wiper arm
http://www.auto-mark.com/e21%20h3%20details.html (7 of 9)04.09.2006 12:27:03
41110100 Aluminium footrest, anodized in silver 41110120 Underbody protection in aluminium for engine 41110315 Oil pan protection in aluminium 51110311 Hartge front spoiler, unpainted 51110320 Hartge FOHA rear spoiler 62110310 Hartge instrument console for 3 VDO instruments 62220100 Hartge instrument set complete with oil temperature, oil pressure
and outside temperature gauages 11220990 Special vibration absorber up to 8500 rpm 11220005 Oil baffle
Hartge also sold as needed:
Hartge/Shrick 292 cam Hartge/Shrick 304 cam Hartge/Shrick 324 cam Hartge/Shrick 328 cam Sport steering with reduction ratio of 2.9:1
3.45:1 with 25% limited slip differential
3.45:1 with 40% limited slip differential
3.45:1 with 75% limited slip differential
http://www.auto-mark.com/e21%20h3%20details.html (8 of 9)04.09.2006 12:27:03
Differential oil cooler with oil pump and thermostat.
BBS 15 inch basket weave wheels for use with Group 2 brakes
We're eternally grateful to Mr. Reg Henshaw, owner of the E21 H3 shown above, a good friend, and also one of our first customers, for all the details provided above!
© 2004, 2006 Auto-Mark Inc. . . . . . auto-mark@charter.net . . . . . .
Nei,og hva er poenget. hullene vil tette seg med bremse støv uansett-derfor er de slissa for å få vekk støvet og du vil minske styrken på skiva med huller.
tenkte på mere kjøling men ser poenget ditt.hehe :roll:
