passer e39 felger på e36?
Vet at dette har sikkert vært oppe mange ganger, men når jeg prøver å søke får jeg bare opp dette:
Could not insert search results
DEBUG MODE
SQL Error : 1062 Duplicate entry '198608967' for key 1
INSERT INTO phpbb_search_results (search_id, session_id, search_array) VALUES(198608967, '22fd44df05ffd32ea2b5a4541896216e', 'a:7:{s:14:"search_results";s:4512:"8021, 10421, 10651, 11107, 11155, 11173, 11196, 11214, 11245, 11250, 11258, 11329, 11362, 11409, 11572, 11625, 11629, 11645, 11662, 11764, 11840, 11863, 12018, 12139, 12161, 12174, 12184, 12208, 12380, 12400, 12505, 12738, 12762, 12790, 12854, 12901, 12930, 13135, 13171, 13216, 13281, 13286, 13293, 13350, 13425, 13453, 13506, 13631, 13651, 13776, 13858, 13859, 14096, 14152, 14153, 14175, 14285, 14396, 14399, 14458, 14562, 14770, 14882, 14916, 15045, 15095, 15097, 15204, 15253, 15383, 15433, 15593, 15625, 15680, 15696, 15727, 15832, 15837, 15856, 15960, 15963, 15980, 16112, 16131, 16177, 16183, 16201, 16243, 16262, 16270, 16354, 16505, 16542, 16574, 16730, 16776, 16864, 16874, 16887, 16947, 16990, 17034, 17039, 17102, 17108, 17125, 17126, 17131, 17137, 17190, 17193, 17245, 17312, 17336, 17361, 17403, 17569, 17646, 11173, 11362, 14175, 14770, 15625, 16270, 16505, 16947, 17336, 17361, 17569, 17646, 17650, 17672, 17717, 17745, 17789, 17870, 17873, 18032, 18069, 18127, 18150, 18170, 18221, 18271, 18321, 18364, 18407, 18431, 18474, 18524, 18554, 18590, 18643, 18660, 18852, 18887, 18899, 18920, 18944, 19001, 19052, 19110, 19115, 19121, 19379, 19402, 19404, 19451, 19461, 19462, 19469, 19500, 19555, 19593, 19600, 19667, 19690, 19691, 19707, 19719, 19740, 19759, 19768, 19930, 19951, 19953, 19992, 19993, 20011, 20040, 20043, 20057, 20064, 20076, 20111, 20131, 20134, 20162, 20198, 20241, 20262, 20294, 20310, 20390, 20422, 20423, 20467, 20471, 20477, 20562, 20608, 20625, 20672 OSV....
Derfor lager jeg en ny tråd!
Kan jeg bruke e39 felger på e36?
ja de passer! alt passer! er bare visse ting du må gjøre me hjulbuene :)
lån deg en vals og vals deg i hel så får du t.o.m 11" breie felger bak på en E36.
5 serie felger vil gå innen for bi skjermen dersom der en under 8" brede.
dette fant jeg ut på min 316 e36, regner ikke med at den er noe spess bredere enn andre e36.
dersom du bruker denne bredden trenger du ikke valse.
Ok... Har ikke tittet på den siden med hjulspesifikasjoner nei...
Har prøvd felgene på bilen min nå og det gikk jo for så vidt greit, men senterringen er ikke rett!
Så nå henger felgen på boltene. Er dette farlig å kjøre med?
ja bør få deg noen nye senter ringer.
selv den minste mm kjenner du gjør utslag når du kjører, spesielt i høyehastighter
hele bilen min ristet bare pga det.
