Hvilken farge er det på denne bilen (kjent bilde av M5)
mhane
Takker Kai, du vet ikke tilfeldigvis den "grå" nederst rundt kantene også?
Fra http://www.bmwe34m5.com/node/23
Date: 9/12/2002 12:28 AM
Subject: correction skirting paint codes
For the sake of good order, clarification and in order to avoid further confusion I believe we need to make a correction to the FAQ-page under heading 'what is the paint code for the gray or black skirting?'
I hv now received an answer from the M-GmbH to my inquiry and unless proofed otherwise we have to assume this to be correct in general -
contrast-colors used for the E34 M5-skirting/aerodynamic package = Sebringgrau, metallic (229) - up to 1991 = Granitsilber, metallic (237 M) - from 1991 = Diamantschwarz, metallic (181 M) - all models
Her er fargekartet i brosjyren fra 1992:
