den er solgt....brukt en gang og virker som den skal.
selges for 1000kr
BMW Carsoft 6.5 Diagnostic Tool for OBD2 OBD FULL KIT
Main Functions:
Digital total test: It gives you a complete idea of the overall condition of the car
Digital single test: It gives you detailed information about the appropriate control unit. Stored errors will be shown in a written report. This report has a short info-text which help you to eliminate the error.
Special functions for some models: Including service interval reset, component activation, live data, LCM reading, sync. EWS and ECU, adaptation values, and coding
Package including:
(1) MCU Controlled Carsoft 6.5 Compatible OBDII Interface with 5 diagnostic LEDs
(2) RS232 Serial Cable
(3) 20 pin to OBDII female cable
(4) CD which contain bmw carsoft version
Descriptions:
MCU controlled Interface for Carsoft 6.5 which is compatible with the original interface. Fully digital line switchings and MCU controlled service reset timing.
READ AND ERASE Error codes of various systems like DME, ABS, AIRBAGS, EGS, etc
RESET Service indicator light, Engine light, Airbag light, Traction control light, etc
RESET Adaptation values of DME and EGS (Automatic Transmission)
PROGRAM features like auto-doors lock on driving, selective locking
READ live data from DME / DDE / EGS >> SYNCHRONIZE EWS and DME in case of a malfunction
WORKS on E30/E31/E32/E34, E36/E39/E38/Z-3/Z-8, E46/E53 series
Features list:
E30 / E31 / E32 / E34 / E36 / E38 / E39 / E46 / E53 / Z-3 / Z-8
Petrol Engines : ALL ENGINES from 1988 to 2004
Additional Features :
· LIVE DATA 1995-2004
· ECU CODING 1995-2004
· ADAPTATION 1995-2004
· EWS Synchronization 1995-2004
E30 / E34 / E36 / E38 /E39 / E46 / E53
Diesel Engines : ALL ENGINES from 1988 to 2004
· ELIVE DATA 1998-2004
· ECU CODING 1998-2004
E30 / E31 / E32 / E34 / E36 / E38 /E39 / E46 / E53 / Z-3 / Z-8
Brake & Traction : ALL SYSTEMS from 1988 to 2004
AIRBAG : ALL AIRBAG SYSTEMS from 1988 to 2004
Air-conditioning : ALL HKL SYSTEMS from 1988 to 2004
BC / MID : BOARD COMPUTER / MULTI INFORMATION DISPLAY
INSTRUMENT CLUSTERS from 1991 to 2004
ECU PROGRAMMING 1995-2004
Change Mileage / Kilometres indication
Change Time indication 24/12 hours scale
Change Language indication into 9 different Languages
Change Temperature indication Celsius / Fahrenheit
DWA : ALARM SYSTEMS
Including : ALARM ACTIVATION COUNTER E34
LCM / CCM : ALL LIGHT/CHECK CONTROL MODULES up to 2004
Reading Original Mileage / Kilometres
Reading CHASSIS ( VIN ) Number
E30 / E31 / E32 / E34 / E36 / E38 / E39 / E53 / E46 / Z-3 / Z-8
ZKE / ZVM : ALL BODY SYSTEMS from 1988 to 2004
COMPLETE ACTIVATION 1988-2004
Auto-Lock after more than 20KM/h
Selective opening (for example: driver door only)
EGS : ALL GEARBOX SYSTEMS from 1988 to 2004
LIVE DATA 1995-2004
EWS : ALL IMMOBILIZE SYSTEMS from 1995 to 2004
SYNCHRONIZATION with ENGINE ECUs up to 2004
E38 / E39 / E46 / E53 / Z-8
CVM : SOFT TOP SYSTEMS to 2004 E46 (some E36 & Z3)
PDC : ALL PARK DISTANCE SYSTEMS from 1995 to 2004
Service Interval : ALL SERVICE SYSTEMS from 1988 to 2004
Service Light RESET 1988-2004
Service MANAGEMENT 1995-2004
Reading of Days since last service
Reading of Fuel Consumption since last service
Programming of next Service / Inspection
Applications list
• E30 - 3 Series
• DME ALL
• DDE ALL
• AB From 1998
• BC/MID ALL
• DWA ALL
• E36-3 Series
• DME ALL
• DDE ALL
• KOMBI Except kompakt
• AB ALL
• ABS ALL
• ASC ALL
• BC/MID ALL
• DWA ALL
• ZKE From 1994
• ZVM Till 1994
• HKL ALL
• EGS ALL
• EWS ALL
• E46 - 3 Series
• DME ALL
• DDE ALL
• KOMBI ALL
• AB ALL
• ABS ALL
• ASC ALL
• DSC ALL
• ZKE ALL
• HKL ALL
• EGS ALL
• EWS ALL
• LCM ALL
• CCM ALL
• PDC ALL
• CVM ALL
• Z3
• DME ALL
• AB ALL
• ABS ALL
• ASC ALL
• ZKE ALL
• HKL ALL
• EGS ALL
• EWS ALL
• E34 - 5 Series
• DME ALL
• DDE ALL
• KOMBI From 02/98
• AB ALL
• ABS From 1992
• ASC From 1992
• BC/MID ALL
• DWA ALL
• ZKE ALL
• HKL ALL
• EGS ALL
• EWS ALL
• E39 - 5 Series
• DME ALL
• DDE ALL
• KOMBI ALL
• AB ALL
• ABS ALL
• ASC ALL
• DSC ALL
• ZKE ALL
• ZVM ALL
• HKL ALL
• EGS ALL
• EWS ALL
• LCM ALL
• CCM ALL
• PDC ALL
• E53 - X5
• DME ALL
• DDE ALL
• KOMBI ALL
• AB ALL
• ABS ALL
• ASC ALL
• DSC ALL
• ZKE ALL
• ZVM ALL
• E32 - 7 Series .... E38, E31, E52
Gjest
