Astri Skrevet Juli 17, 2008 Skrevet Juli 17, 2008 Fant dette da eg surfa litt på Google. Kanskje det kan være til hjelp for noen? BMW Technical Acronyms A - processed vehicle speed signal A - "out" (Aus) AB - Airbag ABL - Brake system warning Lamp (2 color) ABS - Anti-lock Braking System AC - Air Conditioning (from ETK) ACC - Active Cruise Control ACS - Active Comfort Seats ADB(X) - Automatic Differential Braking ADS - engine intake air control ADV - windshield wiper pressure control AEGS - Automatic Electronic Gearbox Control (also EGS) AFM - Air Flow Meter AGD - suction silencer (from ETK) AGR - emission reduction AGS - Adaptive transmission control AG - Automatic Gearbox (transmission) AHK - Active rear-axle Kinematics AHK - trailer hitch (from ETK) AHM - trailer Module (not for US models) AHPS - Advanced HPS AIC - Automatic Interval Control (rain sensor) AKF - activated carbon canister (from ETK) AKS - Active head restraint AKS - pressure regulating device (from ETK) ALC - Automatic Light Control ALR - Automatic Lamp Range Adjustment AMM - Air Mass Meter AMP - radio system AMPlifier ARI - car radio information system (from ETK) ARS - Active Roll Stabilization ASC - All Season traction ASC-EZA - ASC w/ engine timing and injection intervention ASC+T - ASC+ Traction control ASK - Audio System controller (Kontroller) ASR - self starter block relay (from ETK) AST - Automatic Slip control (marketing term) AT - remanufactured part (from ETK) AT - Antenna (from ETK) ATF - Automatic Transmission Fluid (from ETK) ATL - exhaust gas turbo charger (from ETK) AUC - Automatic air recirculation AUT - AUTomatic transmission (from ETK) AVT - Antenna amplifier Tuner AZD - tightening torque specifications (in TIS) A/D – Analog/Digital B - Benzene (gasoline) BAT - BATtery (from ETK) BC - Board Computer BC1 - Body Controller 1 BL - Brake Light (from ETK) BLS - Brake Light Switch BMBT - Board Monitor BS - Block diagram BST - Battery Safety Terminal BVA - Brake pad wear indicator (from ETK) BZM - center console control center BZMF - center console control center, rear CAN – Controller Area Network (Multiple ECU Controller) CAN-Bus - Controller Area Network (bus) CANH-Bus - CAN bus, High CANL-Bus - CAN bus, Low CANP - fuel tank ventilation valve CAS - Car Access System CBC - Corner Braking Control CBS - Condition Based Service CCM - Check Control Module CD - Control Display CDC - Compact Disk Changer CDS - CD player (from ETK) CEL - CELsius (from ETK) CIM - Chassis Integration Module CO - Carbon monOxide (from ETK) COMBI – Electronic Instrument Cluster CON - CONtroller CU - Copper (from ETK) CVM - Convertible top Module CVT - Constantly Variable Transmission CW - drag coefficient (from ETK) D1 - Xenon light/ gas discharge (from ETK) D-Bus - Diagnosis bus (same as TXD) DBC - Dynamic Brake Control DBS - Dynamic Braking System DCS - Dealer Communication System DE – Diagnostic Unit DD - Dynamic motor Drive DDE - Digital Diesel Electronics DIN - German industrial standards DIS - Diagnosis and Information System DISA - Differential air intake control DIVA - continuously variable length intake runners DK - throttle housing/valve DKB - throttle w/ brake intervention DKE – Throttle Increase DKI - throttle position DKR - throttle reduction DKT - throttle position signal DKV - preset throttle position value DME - Digital Motor Electronics DM-TL - Diagnostic Module Tank Leakage DOHC - Double Over Head Camshafts (from ETK) DS - gasket set (from ETK) DSC - Dynamic Stability Control DSP - Digital Sound Processing DTC - Diagnostic Trouble Code (SAE) DTC - Dynamic Traction Control DWA - theft deterrent system DWS - tire pressure Warning System DZM - revolution counter (from ETK) E - "in" (Ein) EBA - installation instructions (from ETK) EBV - Electronic Brake force proportioning ECE - European market version (from ETK) ECM - Engine Control Module (SAE term) ECU - Electronic Control Unit EDC - Electronic Damper Control (from ETK) EDR - Electronic throttle control E-KAT - Electrically heated catalytic converter EZA - see ASC-EZA ECM - Engine Control Module (SAE term) ECO - Controller for I-Drive system EDC - Electronic Dampening Control EDC-K - Electronic Dampening Control - Continuous EDK - Electronic throttle valve EDS - pressure regulator EFH - Electric window lifter (from ETK) EGS - Electronic transmission control EH - Electronic-Hydraulic EHC - Electronic Height Control EKM - Electronic body Module EKP - Electric fuel Pump ELV - Electronic steering lock EM - Electro-Mechanical EMF - Electro-Mechanical parking brake EML - Electronic Motor Load regulation EMV - Electro-Magnetic sensitivity (from ETK) EO - component location EPC - Electronic Parts Catalog (also ETK) EPROM - Erasable/ Programmable chip Memory (from ETK) ETK - Electronic parts catalog (also EPC) ETM - Electrical Troubleshooting Manual ESS - Electronic anti-theft device EV - injection Valve EWS - Electronic drive-away protection FB - Function description FBC - Fading Brake Control FBD - remote control services FBZV - radio frequency locking system FGR – Vehicle Speed Control (Cruise Control) FH - window lifter FHK - rear Heater/ air conditioner FLC - automatic Light Control FRU - Flat Rate Unit FS – Crash Sensor FZV - central lock receiver GAL - speed dependent sound volume GM - General Module GMR - yaw moment control GPS - Global Positioning System GRII - cruise control GRS - rotation Rate Sensor GS – Belt Tensioner GWK - torque converter lock-up control H - "rear" (Hinten) H2 - Xenon headlights HA - rear Axle (from ETK) HC – Hydro Carbon HD - Heavy Duty (from ETK) HDC - Hill Decent Control HFM - Hot Film air mass Meter HG - manual Gearbox (transmission) HKL - Hydraulic trunk lid Lift HLM – Hot Wire Air Mass Meter HPS - Head Protection System HR - Heater control (from ETK) HVA - Hydraulic Valve Adjuster (from ETK) Hz – Hertz (Cycle) I-Bus - Information bus IB - Interior lighting control signal IHKA - automatic Heating and A/C IHKAF - IHKA w/ micro filter IHKR - regulated Heating and A/C IHKRF - IHKR w/ micro filter IHKS - standard Heating and A/C IHPD - Internal High Pressure Deformation IHR - Integrated Heater control (from ETK) IKE - Instrument cluster Electronics ILH - Interior Lighting, rear ILV - Interior Lighting, front IMS - Instant Mobility System (from ETK) IR – Infrared IRS – Infrared Locking System ISC – Idle Speed Control ISIS - Intelligent Safety Integration System ISN - Individual Serial Number ISOFIX - standardized mounts for child restraints ITS - head airbag assembly/ Inflatable Tubular Structure IVM - Integrated power supply Module K-Bus - body bus (Karosserie) KAT - catalytic converter KATON - converter creating (signal) KD - Kick-Down KHI - interface for headphones KL - terminal designation KL15 - run bus (ignition switch run position) KL30 - battery bus (hot at all times) KL31 - ground bus (chassis ground) KL50 - start bus (ignition start position) KLR - accessory bus KO - compressor "on" signal KOMBI - instrument cluster KOREL - compressor relay signal KR – Contact Ring KSK - Knock Sensor KVA - fuel consumption signal/value KW - crankshaft KW - KiloWatt (from ETK) LCM - Lamp Check Module LDP - Leak Diagnosis Pump LEV - Low Emissions Vehicle LEW - Lateral acceleration sensor LHD - Left-Hand Drive (from ETK) LKM - Lamp control Module LL - closed throttle LM - Light Module LMM - air flow meter/sensor LMR - Light alloy wheel LRA - vertical headlight aiming LSM - steering column memory LSZ - Lamp Switching center LVA - air supply system (for EHC system) LWR - vertical headlight aim control LWS-5 - steering angle sensor M-Bus - IHKA/IHKR stepper motor bus MAL - center armrest MBC - Maximum Brake Control MDK - Motorized throttle valve/system MFL - Multi-Function steering wheel MFC - Multi-Function Controller MFU - Multi-Function Clock MID - Multi-Information Display MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp MIR - Multi-Information Radio MMC - Multi-Media Changer MoDiC - Mobile Diagnostic Computer MOST-Bus - Media Oriented System Transport bus MRS - Multiple Restraint System MSR - engine drag torque Regulation MV - Magnetic Valve (solenoid Valve) n-ab - rotational speed, transmission (rpm) n-mot - rotational speed, engine (rpm) NAVI - Navigation module NG - New Generation (as in N73 engine) NG - tilt sensor NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK) NSD - rear muffler (from ETK) NSL - rear fog Lamp (from ETK) NSW - fog lamp (from ETK) NTC - Negative Temperature Coefficient NW - camshaft (from ETK) OBC - On-Board Computer OBD - On-Board Diagnosis (SAE) P/N – Park/Neutral position P-Bus - Periphery bus PB - Pin assignments PBS - Parts Bulletin System (in TIS) PDC - Park Distance Control PGS - Passive Go System PM - Power Module PP – Impact Pad PTC - Positive Temperature Coefficient RLS - Rain-Light Sensor PWG - Pedal position sensor/ potentiometer RA - Repair instructions (in TIS) RAM – Random Access Memory RAL - Aluminum wheels (from ETK) RAL - standard color (from ETK) RDC - tire pressure Control RDS - Radio Data-broadcast System RDW - tire pressure Warning RHD - Right-Hand Drive (from ETK) RM - Relay Module ROZ - Research Octane rating/ fuel grade (from ETK) RPA - tire puncture warning (from ETK) RPS - Rollover Protection System RS - Repair kit (from ETK) RSW - back-up lamp (from ETK) RXD - wake-up Diagnosis line RZV - direct stationary ignition SASL - Satellite, A-pillar left SASR - Satellite, A-pillar right SAV - Sport ACTIVITY Vehicle SB - fuse assignments SBE - Seat occupancy detector/sensor SBFH - Seat module, passenger-side rear SBSL - Satellite, B-pillar left SBSR - Satellite, B-pillar right SBT - SI techniques/ tech reference information (in TIS) SCA - Soft Close Automatic/Actuator SD - sliding roof (from ETK) SD - silencer/ muffler (from ETK) SE - Special Equipment (from ETK) SES - voice recognition System SFAH - Seat module, driver's side rear SFZ - Satellite, vehicle center SG - control unit SGS - Seat integrated belt System SHD - sliding/ lifting roof (from ETK) SHD - Sunroof module (also SHDM) SI - Service Information (in TIS) SIA - Service Interval system (ver. I, II, III, IV, etc.) SII - Service Interval Indicator SIL - SILicon (from ETK) SIM - Safety Information Module SINE - Siren/tilt sensor SKD - Steel sliding roof (from ETK) SKHD - Steel sliding/ lifting roof (from ETK) SM - Seat Module SM/SPM - Seat/Mirror Memory SMBF - Seat Module, passenger side SMFA - Seat Module, driver's side SMG - Sequential Manual Gearbox SP - Schematic SRA - headlight/fog light cleaning SRS - Supplementary Restraint System SSD - Steel sliding roof (from ETK) SSH - Seat Satellite, rear seat ST - connector views Steptronic - transmission shift control STVL - Satellite, left front door STVR - Satellite, right front door SVS - Speech processing System SWR - headlamp cleaning system (from ETK) SWZ - Special tool listings (in TIS) SZL - Switch center, steering column SZM - central switch center Module TAGE - door handle Electronics TCM - Transmission Control Module TD - engine speed signal (ignition pulse) TD - Technical Data (in TIS) TE - fuel evaporation control TEL - TELephone control unit TEV - evaporative purge control THZ - Tandem master cylinder (from ETK) ti - Injector "on" Time (duration) TIS - Technical Information System TL - part throttle / load signal TLEV - Transitional Low Emission Vehicle TMBFT - door Module, passenger side TMBFTH - door Module, passenger side rear TMFAT - door Module, driver's side TMFATH - door Module, driver's side rear TP - Tandem Pump (from ETK) TPS - Throttle Position Switch/Sensor TR - engine speed signal (rpm) TR - TRansistor (from ETK) TRG - fuel level sensor (from ETK) TRI - Technical Reference Information (also SBT) TRS - battery isolation Switch TSD - Torsional vibration dampener (from ETK) TSH - door lock Heating TSZI - Transistorized coil Ignition system (from ETK) TU - Technical Update (as in M50tu) TXD - Transmitting Diagnosis line U-batt - Battery voltage U-vers - supply voltage UERSS - rollover bar (from ETK) URS - rollover protection System USIS - Ultrasonic passenger compartment Sensor V - "front" (Vorn) V - vehicle road speed VA - front Axle (from ETK) VAT - front axle support (from ETK) VANOS - Variable camshaft timing VEP - distributor-type injection Pump (from ETK) VID - VIDeo module VL - full load (wide open throttle) VSD - front muffler (from ETK) VVT – Valve tronic WBG - hazard warning switch (from ETK) WIM - Wiper control Module WK - torque converter lock-up clutch WSS – Wind Shield (from ETK) WT – Valve tronic control unit Z - "central" (Zentrum) ZAB - ignition fade-out (reduction) ZAE - central Airbag Electronics ZAS - ignition starter switch (from ETK) ZGM - central Gateway Module ZK - cylinder head (from ETK) ZKE - central body Electronics ZKH - cylinder head cover (from ETK) ZMS - dual-Mass flywheel (from ETK) ZV - central locking system ZS - central lock (from ETK) ZSD - center muffler (from ETK) ZV - central locking system (from ETK) ZVM - central locking Module ZWD - idle control valve
Astri Skrevet Juli 17, 2008 Forfatter Skrevet Juli 17, 2008 Code Description: P1083 Fuel Control Mixture Lean (Bank 1 Sensor 1) P1084 Fuel Control Mixture Rich (Bank 1 Sensor 1) P1085 Fuel Control Mixture Lean (Bank 2 Sensor 1) P1086 Fuel Control Mixture Rich (Bank 2 Sensor 1) P1087 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 1) P1088 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 1 Sensor 1) P1089 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 2) P1090 Pre-Catalyst Fuel Trim Too Lean Bank 1 P1091 Pre-Catalyst Fuel Trim Too Rich Bank 1 P1092 Pre-Catalyst Fuel Trim Too Lean Bank 2 P1093 Pre-Catalyst Fuel Trim Too Rich Bank 2 P1094 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1) P1095 2 Sensor Circuit Slow Switching From Lean to Rich (Bank 1 Sensor 1) P1096 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 2 Sensor 1) P1097 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 1 Sensor 1) P1098 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 2 Sensor 2) P1111 Engine Coolant Temperature Radiator Outlet Sensor Low Input P1112 Engine Coolant Temperature Radiator Outlet Sensor High Input P1115 Coolant Temperature Sensor Plausibility P1116 Mass Or Volume Air Flow Circuit Range/Performance Problem (Bank 2) P1117 Mass Or Volume Air Flow Circuit Low Input (Bank 2) P1118 Mass Or Volume Air Flow Circuit High Input (Bank 2) P1120 Pedal Position Sensor Circuit P1121 Pedal Position 1 Range/Performance Problem P1122 Pedal Position 1 Low Input P1123 Pedal Position 1 High Input P1132 O2 Sensor Heater Control Circuit (Bank 1 Sensor 1) P1133 O2 Sensor Heater Control Circuit (Bank 2 Sensor 1) P1134 O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2) P1135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) P1136 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) P1137 O2 Sensor Heater Circuit Signal Intermittant (Bank 1 Sensor 2) P1138 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) P1139 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) P1140 Mass or Volume Air Flow Circuit Range/Performance Problem P1145 Solenoid Valve Running Losses Control Circuit Electrical P1151 O2 Sensor Heater Circuit Signal Intermittant (Bank 2 Sensor 1) P1152 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1) P1153 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1) P1155 O2 Sensor Heater Circuit Intermittant (Bank 2 Sensor 2) P1156 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 2) P1157 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 2) P1158 Fuel Trim Additve Bank 1 Low P1159 Fuel Trim Additve Bank 1 High P1160 Fuel Trim Additve Bank 2 Low P1161 Fuel Trim Additve Bank 2 High P1162 Fuel Trim Additve Per Ignition Bank 1 Low P1163 Fuel Trim Additve Per Ignition Bank 1 High P1164 Fuel Trim Additve Per Ignition Bank 2 Low P1165 Fuel Trim Additve Per Ignition Bank 2 High P1174 Fuel Trim Adaptation Additve Bank 1 Malfunction P1175 Fuel Trim Adaptation Additve Bank 2 Malfunction P1176 O2 Sensor Slow Response Bank 1 P1177 O2 Sensor Slow Response Bank 2 P1178 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 1) P1179 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 1) P1180 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 2) P1181 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 2) P1182 O2 Sensor (Bank 1 Sensor 2) Open Circuit During Coast Down Fuel Cut-off P1183 O2 Sensor (Bank 2 Sensor 2) Open Circuit During Coast Down Fuel Cut-off P1186 O2 Sensor Heater Control Circuit (Bank 1 Sensor 2) P1187 O2 Sensor Heater Control Circuit (Bank 2 Sensor 2) P1188 Fuel Control (Bank 1 Sensor 1) P1189 Fuel Control (Bank 2 Sensor 1) P1190 Pre-catalyst Fuel Trim System Bank 1 P1191 Pre-catalyst Fuel Trim System Bank 2 P1192 Post-catalyst Fuel Trim System Bank 1 P1193 Post-catalyst Fuel Trim System Bank 2 P1221 Pedal Position Sensor 2 Range/Performance Problem P1222 Pedal Position Sensor 2 Low Input P1223 Pedal Position Sensor 2 High Input P1270 Control Module Self-Test, Torque Monitoring P1271 Ambient Air Pressure Sensor Electrical P1283 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Electrical P1284 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal Low P1285 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal High P1287 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Electrical P1288 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal Low P1289 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal High P1313 "A" Camshaft Position Plausibility P1317 "B" Camshaft Position Plausibility P1327 Knock Sensor 2 (Bank 1) Low Input P1328 Knock Sensor 2 (Bank 1) High Input P1332 Knock Sensor 4 Low Input P1333 Knock Sensor 4 High Input P1340 Multiple Cylinder Misfire During Start P1341 Multiple Cylinder Misfire With Fuel Cut-off P1342 Misfire During Start Cylinder 1 P1343 Misfire Cylinder 1 With Fuel Cut-off P1344 Misfire During Start Cylinder 2 P1345 Misfire Cylinder 2 With Fuel Cut-off P1346 Misfire During Start Cylinder 3 P1347 Misfire Cylinder 3 With Fuel Cut-off P1348 Misfire During Start Cylinder 4 P1349 Misfire Cylinder 4 With Fuel Cut-off P1350 Misfire During Start Cylinder 5 P1351 Misfire Cylinder 5 With Fuel Cut-off P1352 Misfire During Start Cylinder 6 P1353 Misfire Cylinder 6 With Fuel Cut-off P1354 Misfire During Start Cylinder 7 P1355 Misfire Cylinder 7 With Fuel Cut-off P1356 Misfire During Start Cylinder 8 P1357 Misfire Cylinder 8 With Fuel Cut-off P1358 Misfire During Start Cylinder 9 P1359 Misfire Cylinder 9 With Fuel Cut-off P1360 Misfire During Start Cylinder 10 P1361 Misfire Cylinder 10 With Fuel Cut-off P1362 Misfire During Start Cylinder 11 P1363 Misfire Cylinder 11 With Fuel Cut-off P1364 Misfire During Start Cylinder 12 P1365 Misfire Cylinder 12 With Fuel Cut-off P1384 Knock Sensor 3 Circuit P1385 Knock Sensor 4 Circuit P1386 Control Module Self-test, Knock Control Baseline Test Bank 1 P1396 Crankshaft Position Sensor Segment Timing Plausibility P1397 Camshaft Position Sensor "B" Circuit (Bank 1) P1400 Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1) P1401 Heated Catalyst Current too High During Heating (Bank 1) P1402 Heated Catalyst Power Switch Overtemperature Condition (Bank 1) P1403 Carbon Canister Shut Off valve Control Circuit Electrical P1404 Heated Catalyst Current too High During Heating (Bank 2) P1405 Heated Catalyst Power Switch Overtemperature Condition (Bank 2) P1406 Heated Catalyst Internal Control Module Checksum/ROM Error P1413 Secondary Air Injection Pump Relay Control Circuit Signal Low P1414 Secondary Air Injection System Monitor Circuit High P1420 Secondary Air Valve Control Circuit Electrical P1421 Secondary Air System Bank 1 P1422 Secondary Air System Bank 2 P1432 Secondary Air Injection System Incorrect Flow Detected P1438 Purge Control Valve Control Open Circuit P1439 Purge Control Valve Control Circuit Signal Low P1440 Purge Control Valve Control Circuit Signal High P1441 Leakage Diagnostic Pump Control Open Circuit P1442 Leakage Diagnostic Pump Control Circuit Signal Low P1443 Leakage Diagnostic Pump Control Circuit Signal High P1444 Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit P1445 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low P1446 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal High P1447 Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching P1448 Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching P1449 Diagnostic Module Tank Leakage (DM-TL) Pump Too High P1450 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit P1451 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low P1452 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High P1453 Secondary Air Injection Pump Relay Control Circuit Electrical P1454 Secondary Air Injection Pump With Series Resistor Control Circuit Electrical P1456 Heated Catalyst Heater Power Supply Open Circuit (Bank 1) P1457 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 1) P1459 Heated Catalyst Heater Power Supply Open Circuit (Bank 2) P1460 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 2) P1461 Heated Catalyst Gate Voltage Signal Low P1462 Heated Catalyst Internal Control Module Checksum/ROM Error P1463 Heated Catalyst Battery Temperature Sensor 1 Electrical P1464 Heated Catalyst Battery Temperature Sensor 2 Electrical P1465 Heated Catalyst Battery Temperature Sensor 1 or 2 Plausibility P1466 Heated Catalyst Power Switch Temperature Sensor Plausibility P1467 Heated Catalyst Comparison Battery Voltages of Power Switches Plausibility P1468 Heated Catalyst Battery Disconnecting Switch Plausibility P1470 Leakage Diagnostic Pump Control Circuit Electrical P1472 Diagnostic Module Tank leakage (DM-TL) Switching Solenoid Control Circuit Electrical P1473 Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility P1475 Leakage Diagnostic Pump Reed Switch Did Not Close P1476 Leakage Diagnostic Pump Clamped Tube P1477 Leakage Diagnostic Pump Reed Switch Did Not Open P1500 Idle Speed Control Valve Stuck Open P1501 Idle Speed Control Valve Stuck Closed P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal High or Low P1503 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low P1504 Idle Speed Control Valve Closing Solenoid Control Open Circuit P1505 Idle Speed Control Valve Closing Solenoid Control Circuit Electrial P1506 Idle Speed Control Valve Open Solenoid Control Circuit Signal High P1507 Idle Speed Control Valve Open Solenoid Control Circuit Signal Low P1508 Idle Speed Control Valve Opening Solenoid Control Open Circuit P1509 Idle Speed Control Valve Opening Solenoid Control Circuit Electrial P1510 Idle Speed Control Valve Stuck P1511 DISA Control Circuit Electrical P1512 DISA Control Circuit Signal Low P1513 DISA Control Circuit Signal High P1519 "A" Camshaft Position Actuator Bank 1 P1520 "B" Camshaft Position Actuator Bank 1 P1522 "A" Camshaft Position Actuator Bank 2 P1523 "A" Camshaft Position Actuator Signal Low Bank 1 P1524 "A" Camshaft Position Actuator Signal High Bank 1 P1525 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1526 "A" Camshaft Position Actuator Control Open Circuit Bank 2 P1527 "A" Camshaft Position Actuator Control Circuit Signal Low Bank 1 P1528 "A" Camshaft Position Actuator Control Circuit Signal High Bank 1 P1529 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 1 P1530 "B" Camshaft Position Actuator Control Circuit Signal High Bank 1 P1531 "B" Camshaft Position Actuator Control Open Circuit Bank 1 P1532 "B" Camshaft Position Actuator Control Open Circuit Bank 2 P1533 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 2 P1534 "B" Camshaft Position Actuator Control Circuit Signal High Bank 2 P1540 Pedal Position Sensor P1541 Pedal Position Sensor Double Error P1542 Pedal Position Sensor Electrical P1543 Pedal Position Sensor P1544 Pedal Position Sensor P1545 Pedal Position Sensor P1546 Pedal Position Sensor P1550 Idle Speed Control valve Closing Solenoid Control Circuit Electrical P1551 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1552 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1556 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1560 "B" Camshaft Position Actuator Control Open Circuit Bank 1 P1564 Control Module Selection P1565 "B" Camshaft Position Actuator Control Open Circuit Bank 1 P1569 "A" Camshaft Position Actuator Control Open Circuit Bank 2 P1580 Throttle Valve Mechanically Stuck P1581 "B" Camshaft Position Actuator Control Open Circuit Bank 2 P1589 Control Module Self Test, Knock Control Test Pulse Bank 1 P1593 DISA Control Circuit Electrical P1594 "B" Camshaft Position Actuator Control Open Circuit Bank 2 P1602 Control Module Self Test, Control Module Defective P1603 Control Module Self Test, Torque Monitoring P1604 Control Module Self Test, Speed Monitoring P1607 CAN Version P1608 Serial Communicating Link Control Module P1609 Serial Communicating Link EML P1611 Serial Communicating Link Transmission Control Module P1619 MAP Cooling Control Circuit Signal Low P1620 MAP Cooling Control Circuit Signal High P1622 MAP Cooling Control Circuit Electrical P1623 Pedal Position Sensor Potentiometer Supply P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical P1625 Pedal Position Sensor Potentiometer Supply Channel 2 Electrical P1632 Throttle Valve Adaptation; Adaptation Condition Not Met P1633 Throttle Valve Adaptation; Limp Home Position P1634 Throttle Valve Adaptation; Spring Test Failed P1635 Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted P1636 Throttle Valve Control Circuit P1637 Throttle Valve Position Control; Control Deviation P1638 Throttle Valve Position Control; Throttle Stuck Temporarily P1639 Throttle Valve Position Control; Throttle Stuck Permanently P1640 Internal Control Module (ROM/RAM) Error P1690 Malfunction Indicator Lamp (MIL) Electrical P1734 Pressure Control Solenoid "B" Electrical P1738 Pressure Control Solenoid "C" Electrical P1743 Pressure Control Solenoid "E" Electrical P1744 Pressure Control Solenoid "A" Electrical P1746 Transmission Control Module Output Stage P1747 CAN Bus Monitoring P1748 Transmission Control Module Self Test P1749 Secondary Pressure Solenoid Communication Error P1750 Secondary Pressure Solenoid Circuit Range/Performance P1751 Secondary Pressure Solenoid Open Circuit P1761 Shift Solenoid Malfunction P1765 CAN Throttle Valve P1770 CAN Torque Interface P1780 CAN Torque Reduction Dette var fra et forum der eg verken forsto språket eller skrifta deres, men håper dette kan være brukende.
