M20 turbokit
  • 4 weeks later...
DESCRIPTION: 84-91 BMW E30 320/325/323 L6 T3 /t4 custom turbo kit ( ALL E30 WITH M20 ENGINE)
Including following item
-turbo manifold 84-91 BMW E30 320/322/325
-godspeed TYPE-M INTERCOOLER (20X6X2.75" CORE SIZE)
-t3/t4 internal wastegate turbo
-bzs blow off valve
-oil line, oil return lines & fittings
-universal 2.5" aluminum intercooler piping with silicone
CUSTOMER IS REQUIRE TO CUSTOM MAKE THE DOWN PIPE
TURBO SPEC:
INLET 2"
OUTLET 3"
BEARING TYPE WET FLOAT BEARINGS
OIL INLET 1/8 NPT
MAX PSI CAPACITY 27PSI
COMPRESSOR .48 AR COMPRESSOR
TURBINE .60 AR TURBINE
FLANGE TYPE T3 FLANGE
DOWN PIPE FLANGE TYPE 2.5" V BAND
MAX HP 350HP
Kjøpt hos advan_racing
