snarvei til og nullstille service e39?
er det noe snarvei for og nullstille en 97 e39?
som e30\36 der en jorder pin nr.7 til jord og tar på tenning...
fant noe her til deg:) det fungerer på min E39
Resetting the service indicator lights on e39 BMW's is relatively the same as with e34 cars.
The service indicator lights are reset by connecting pin 7 to pin 19 (ground) (see illustration below for pin identification.). The proper way to do this is to have the ignition off and place a jumper wire between pins 7 and 19 (make sure you get the right pins!). Then turn the ignition switch to position 2 (run, NOT start), when the service light goes out, turn the ignition off. This should take a few seconds for an oil reset, 8-10 seconds for an inspection reset. All green lights should come on when the service light goes out. The difference between resetting the oil service light and the inspection light is in the length of time you have the jumper in place with the ignition on. This means that if you are resetting the oil service light, you should turn off the ignition immediately after the light goes out. If you leave the jumper in too long with the ignition on, you will perform an inspection reset as well and the next service indicator will come up as an oil service rather than an inspection
Evt kan du dette innom meg, har utstyr til det.
ok, kan du også fjerne feilkoder som at en lyspære er gåen?
og finne ut hvorfor airbaglampe lyser?
send meg en pm. ville kjøpe slik en ting gjennom jobb(wurth) men vi har kuttet den ut ser dere,
