Harman kardon surround forsterker SOLGT!!
kraftig surround forsterker.
fungerer 100%
Selges ikke under 4500,- :wink:
tlf: 48193883
Bilder:
PECIFICATIONS: Audio
Stereo Mode
Continuous Average Power (FTC) per Channel : 65 Watts per channel, 20Hz – 20kHz, @ <0.07% THD, both channels driven into 8 ohms
Seven-Channel Surround Modes, Power per Individual Channel,
All Channels Operating at Full Power :
Front L & R Channels : 55 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
Center Channel : 55 Watts @ <0.07% THD, 20Hz – 20kHz into 8 ohms
Surround Channels (L & R Side, L & R Back) : 55 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
Input Sensitivity/Impedance, Linear (High-Level) : 200mV/47k ohms
Signal-to-Noise Ratio (IHF-A) : 100dB
Surround System Adjacent Channel Separation :
Dolby® Pro Logic® I and II : 40dB
Dolby® Digital : 55dB
DTS® : 55dB
Frequency Response at 1W (+0dB, –3dB) : 10Hz – 130kHz
High Instantaneous Current Capability (HCC) : ±35 Amps
Transient Intermodulation Distortion (TIM) : Unmeasurable
Slew Rate : 40V/µsec
FM Tuner
Frequency Range : 87.5–108.0MHz
Usable Sensitivity : IHF 1.3µV/13.2dBf
Signal-to-Noise Ratio : Mono/Stereo 70/68dB
Distortion : Mono/Stereo 0.2/0.3%
Stereo Separation : 40dB @ 1kHz
Selectivity : ±400kHz, 70dB
Image Rejection : 80dB
IF Rejection : 90dB
AM Tuner
Frequency Range : 520–1720kHz
Signal-to-Noise Ratio : 45dB
Usable Sensitivity : Loop 500µV
Distortion : 1kHz, 50% Mod 0.8%
Selectivity : ±10kHz, 30dB
Video
Television Format : NTSC/PAL
Input Level/Impedance : 1Vp-p/75 ohms
Output Level/Impedance : 1Vp-p/75 ohms
Video Frequency Response :
Composite and S-Video : 10Hz–8MHz (–3dB)
Component Video : 10Hz–30MHz (–3dB)
General
Power Requirement : AC 220-240V / 50Hz
Power Consumption : 118W idle, 890W maximum (7 channels driven)
Unit Dimensions :
Width : 440mm (17.3 inches)
Height : 168mm (6.6 inches)
Depth : 381mm (15 inches)
Unit Weight : 13.9kg (30.6 lb)>
Jeg har to sub utganger på min AVR 745. Tror det er den eneste som har det av den serien der?! Men jeg bruker kun 1 sub, å det holder i massevis :)
Men H/K anbefales på det sterkeste. Lykke til med salget ;)
