-3200 is CLASS-D mono bass amplifier, it can delivery up to 3000W at 2ohm load.
3000Wrms Class-D amplifier.
2/1-channel mode for versatile wiring.
Double Side PCB and SMD components.
Adjustable Input level, LPF, Subsonic, bass boost function.
Advanced short circuit, overload, over heat protection.
Heavy-duty terminals.
Optional wired remote controller.
RMS Power at 14.4V (into 1 ohm 50Hz THD+N < 2.5%)
2 X 1500 Watt
RMS Power at 14.4V (into 2 ohm 50Hz THD+N < 2.5%)
3000 Watt
RMS Power at 14.4V (into 4 ohm 50Hz THD+N < 1%)
1800 Watt
LPF frequency
40~180Hz Adjustable
Subsonic switch
Yes
Subsonic frequency
10~50Hz
Frequency Response
10Hz--180Hz
Bassboost frequency
30-80Hz
Bassboost gain
0~12dB
Low Pass Filter
24dB/Oct
SUBSONIC Filter
12dB/Oct
Operating voltage
DC10V--16V
Remote control
Optional
High-grade Nickel-plated, heavy duty terminal block type connectors
Yes
protection
Short circuit, Overload, over Thermal
Dimensions (HxWxD)
106mm x 228mm x376mm
tenkte 2000 kr før den.. men open før bud.
forsterker så driv mange store elementer eller flere;) selges snarest...
