325m24v Skrevet September 8, 2009 Share Skrevet September 8, 2009 hei kunne tenkt meg å fått lest av feilkoder på min m20b25 da den ikke er helt frisk. finnes det noe hjemme utstyr for dette.? mvh ole Lenke til kommentar Del på andre sider More sharing options...
325m24v Skrevet September 11, 2009 Forfatter Share Skrevet September 11, 2009 bump Lenke til kommentar Del på andre sider More sharing options...
Rayb Skrevet September 11, 2009 Share Skrevet September 11, 2009 Carsoft 6.5 kan brukes på E30 etter faceliften i 1988. Da kom også den med den store kontakten i motor rommet. Fant dette etter et google søk... "Now on the E30 models, get in the car and put the key in the ignition and turn it to the second turn or “ON” position, but do not start the car. Now, press the accelerator pedal all the way to the floor, then let it release all the way back. Now repeat the depress/release cycle 4 more times fairly quickly, but not too fast. It may take some time to get this timing down correct. It should only take you a few seconds to do this. What this does is activate the wide-open throttle switch and the idle switch 5 times. This then sends a signal to the Motronic ECU to send fault codes to the Service Indicator Light." Here is the list of codes and what they indicate: 1211 DME Control Unit 1215 Air Mass Sensor 1216 Throttle Potentiometer 1218 Output Stage, Group 1 1219 Output Stage, Group 2 1221 Oxygen Sensor 1 1212 Oxygen Sensor 2 1222 Lambda Control 1 1213 Lambda Control 2 1223 Coolant Temperature Sensor 1224 Intake Air Temperature Sensor 1225 Knock Sensor 1 1226 Knock Sensor 2 1227 Knock Sensor 3 1228 Knock Sensor 4 1231 Battery Voltage/DME Main Relay 1232 Throttle Idle Switch 1233 Throttle Wide Open Throttle Switch 1234 Speedometer A Signal 1237 A/C Compressor Cut Off 1242 A/C Compressor 1243 Crankshaft Pulse Sensor 1244 Camshaft Sensor 1245 Intervention AEGS 1247 Ignition Secondary Monitor 1251 Fuel Injector 1 (or group 1) 1252 Fuel Injector 2 (or group 2) 1253 Fuel Injector 3 1254 Fuel Injector 4 1255 Fuel Injector 5 1256 Fuel Injector 6 1257 Fuel Injector 7 1258 Fuel Injector 8 1261 Fuel Pump Relay Control 1262 Idle Speed Actuator 1263 Purge Valve 1264 EGO Heater 1265 Fault Lamp (check engine light) 1266 VANOS 1267 Air Pump Relay Control 1271 Ignition Coil 1 1272 Ignition Coil 2 1273 Ignition Coil 3 1274 Ignition Coil 4 1275 Ignition Coil 5 1276 Ignition Coil 6 1277 Ignition Coil 7 1278 Ignition Coil 8 1281 Control Unit Memory Supply 1282 Fault Code Memory 1283 Fuel Injector Output Stage 1286 Knock Control Test Pulse 1444 No Fault Codes Lenke til kommentar Del på andre sider More sharing options...
Amistad Skrevet Juli 30, 2020 Share Skrevet Juli 30, 2020 Gjelder dette preface også ? Lenke til kommentar Del på andre sider More sharing options...
