DSC feil
bmwsel
Skiftet hjul fra 205/55/16 vinterhjul til
sommerhjul som har 205/50/17 fremme og 225/45/17 bak.
Etter none dager fikk jeg DSC feilure.
Kan differansen på omkrets gi utslag på DSC failure?
Dette er en 2005 mod E87 116i
Jeg har har tatt diagnose på bilen, følgende feil dukket opp (se under). Sletter error memory, men etter et par dager dukket samme feil opp. Fremdelse med km 72576. Noen som har peiling på dette?
E R R O R M E M O R Y
Date: 22.07.2010 14:42:16
ECU: ME9N45
JobStatus: OKAY
Variant: ME9N45
RESULT: 3 error in error memory !
2CF8 CDKDK - DK-poti sensor
P110D Throttle Position Sensor A and B Range/Performance
Error counter: 16
Logistic counter: 39
1. Umweltsatz
Mileage 72576 km
Engine speed (nmot) 1640.00 /min
Throttle valve angle relative to throttle valve connection (wdkba) 11.37 % DK
Voltage of throttle valve potentiometer1 (udkp1_u) 0.97 V
Voltage of throttle valve potentiometer2 (udkp2_u) 3.74 V
2. Umweltsatz
Mileage 72648 km
Engine speed (nmot) 1840.00 /min
Throttle valve angle relative to throttle valve connection (wdkba) 6.28 % DK
Voltage of throttle valve potentiometer1 (udkp1_u) 0.78 V
Voltage of throttle valve potentiometer2 (udkp2_u) 3.98 V
3. Umweltsatz
Mileage 72872 km
Engine speed (nmot) 1080.00 /min
Throttle valve angle relative to throttle valve connection (wdkba) 3.14 % DK
Voltage of throttle valve potentiometer1 (udkp1_u) 0.70 V
Voltage of throttle valve potentiometer2 (udkp2_u) 3.63 V
Error throttle valve potentiometer 1 or throttle valve potentiometer 2
Test conditions fulfilled
Error not present now, but already stored
Error would cause a warning lamp to light up
Diagnostic active
Cycle flag set
Error in debounce phase
Error code: 2C F8 A8 25 11 0D 10 27 23 70 29 1D 32 C0 23 79
2E 10 28 CC 23 95 1B 08 24 BA
2CFA CDKDK2P - Throttle-valve potentiometer 2
P0221 Throttle/Pedal Position Sensor/Switch 'B' Circuit Range/Performance
Error counter: 16
1. Umweltsatz
Mileage 72576 km
Nominal value of throttle valve relative to bottom connection(wdks) 11.33 %
Ambient temperature (tumg) 9.75 Degrees C
2. Umweltsatz
Mileage 72648 km
Nominal value of throttle valve relative to bottom connection(wdks) 5.86 %
Ambient temperature (tumg) 19.50 Degrees C
3. Umweltsatz
Mileage 72872 km
Nominal value of throttle valve relative to bottom connection(wdks) 3.52 %
Ambient temperature (tumg) 12.75 Degrees C
Throttle valve potentiometer 2 implausible to air mass
Diagnostic active
Cycle flag set
Error code: 2C FA A8 25 02 21 10 27 23 70 29 1D 4D 32 23 79
2E 0F 5A 28 23 95 1B 09 51 24
2CF9 CDKDK1P - Throttle-valve potentiometer 1
Error counter: 22
Logistic counter: 38
1. Umweltsatz
Mileage 72576 km
Engine speed (nmot) 840.00 /min
Nominal value of throttle valve relative to bottom connection(wdks) 2.73 %
Voltage of throttle valve potentiometer2 (udkp2_u) 4.37 V
2. Umweltsatz
Mileage 72648 km
Nominal value of throttle valve relative to bottom connection(wdks) 2.34 %
3. Umweltsatz
Mileage 72888 km
Engine speed (nmot) 960.00 /min
Voltage of throttle valve potentiometer2 (udkp2_u) 3.94 V
Throttle valve potentiometer 1 implausible to air mass
Error not occurred yet
Diagnostic active
Cycle flag set
Error code: 2C F9 88 05 00 00 16 26 23 70 15 07 4D E0 23 79
15 06 5A E0 23 97 18 06 51 CA
Problemet er hvertfall ikke at du har bytta fra vinter til sommerdekk, problemet er i tilfelle forskjellig dim foran og bak. Bakhjulene dine er litt mindre enn forhjulene dine. Dermed snurrer de litt fortere enn forhjula, det kan oppfattes som spinning av DSC. DSC vil i slike tilfeller prove aa begrense motorkraften osv... MEN jeg tror ikke den lille forskjellen skal ha noe aa si. Bakhjula har 0,4% mindre rulleomkrets enn forhjula. Ta en diagnose med bedre utstyr, dvs bmw forhandler helst.
Samme feimeldinger kom igjen i dag.
I tillegg fikk jeg en ny:
5E19 - CAN/DME/DDE, engine tourque not adjustable.
Milage 91176km
Physical value is outside of valid range.
Test condition fulfilled
Error not preset now, but already stored
Error would cause a warninglamp to light up.
Noen som vet hva dette er ??
