Stephan.s Skrevet August 29, 2011 Share Skrevet August 29, 2011 Selger basskasseløsningen jeg hadde i e34n, da jeg innser at den ikke kommer til å bli brukt igjen. JBL Power PX-300.4 • 123.5W RMS x 4 channels at 4 ohms and <1% THD + N • Signal-to-noise ratio: 76.64dBA (reference 1W into 4 ohms) • 358W RMS x 2 channels at 4 ohms, 14.4V supply and <1% THD + N • 169W RMS x 4 channels at 2 ohms, 14.4V supply and <1% THD + N • Dynamic power: 385W at 4 ohms x 2 channels • Effective damping factor: 6.383 at 4 ohms • Frequency response: 16.6Hz – 500kHz (–3dB) • Maximum input signal: 5.9V • Maximum sensitivity: 250mV • Output regulation: .39dB at 4 ohms • Dimensions (L x W x H): 12-1/4" x 17" x 2-9/16" Rockford Fosgate Punch P212D4 • 12" Dual 4 ohms Punch Stage 2 Subwoofer • Anodized aluminum voice coil former • High excursion large roll surround • •Linear spider • Massive double stacked magnet motor assembly • Precision stamped CRS basket w/ removable motor cover • Parabolic triangular cone geometry support system • Removable and reversible screw concealing ring • Power Handling: 250 watts RMS 500 watts Peak • Sensitivity: 85.5 dB • Frequency Response: 20 Hz - 0.2 kHz • Mounting Depth: 5.25" • Motor Size: 60 oz. double stacked Kasse bygget i 22mm spon, tilpasset skiposehullet i e34 sedan. Plug and play. Selges samlet oppsatt slik som avbildet; kasse, bass og forsterker. 1500,- BUD Kan hentes i Lillestrømområdet. Lenke til kommentar Del på andre sider More sharing options...
Stephan.s Skrevet August 31, 2011 Forfatter Share Skrevet August 31, 2011 Lenke til kommentar Del på andre sider More sharing options...
Bjarte87 Skrevet September 1, 2011 Share Skrevet September 1, 2011 Sender du dette send meg pm da er eg int;-) Mvh Lenke til kommentar Del på andre sider More sharing options...
Stephan.s Skrevet September 7, 2011 Forfatter Share Skrevet September 7, 2011 Satser på salg i nærområdet i første omgang, da det er litt tungvindt å sende denne 'kladden' Lenke til kommentar Del på andre sider More sharing options...
Bjarte87 Skrevet September 20, 2011 Share Skrevet September 20, 2011 Ser den;) Hvertfall int i forsterkeren om du selger separat:) Mvh Lenke til kommentar Del på andre sider More sharing options...
Stephan.s Skrevet Oktober 24, 2011 Forfatter Share Skrevet Oktober 24, 2011 opp Lenke til kommentar Del på andre sider More sharing options...
spruddel Skrevet Oktober 24, 2011 Share Skrevet Oktober 24, 2011 Blir vel kjøp av E34 snart, ser ut til at jeg får solgt bilen min straks, så hvis det blir E34 sedan som har skiluke og dette spiller bra, så kan det være aktuelt Lenke til kommentar Del på andre sider More sharing options...
Stephan.s Skrevet Desember 18, 2011 Forfatter Share Skrevet Desember 18, 2011 Opp. Bass og forsterker kostet rundt 4000,- når jeg handlet det. Ikke det beste oppsettet, men spiller helt kurant. Lenke til kommentar Del på andre sider More sharing options...
Stephan.s Skrevet Januar 10, 2012 Forfatter Share Skrevet Januar 10, 2012 opp Lenke til kommentar Del på andre sider More sharing options...
spruddel Skrevet Januar 10, 2012 Share Skrevet Januar 10, 2012 Selger du forsterker løst? Lenke til kommentar Del på andre sider More sharing options...
