Bmw mann Skrevet November 17, 2011 Skrevet November 17, 2011 NYPRIS 6500,- Installert og testet ut kun av en kamerat. Demontert pga salg av bilen uten turbo oppsettet. Moristech interceptors stand apart from most other piggy back computers because fuel mixture is modified by intercepting the actual fuel injector pulse signal, not by modifying Airflow meter or MAP sensor signals. This method enables engines with larger size injectors, even low resistance injectors, to be tuned with ease. Fuel can be modified +/-100% and ignition timing up to +/-50 degrees totally independent of each other at any engine speed or load. An on board 22psi boost MAP sensor ensures tunability even if the original engine sensors have been 'saturated' or reached their maximum reading. Tuning is performed using Windows based software and a supplied communication cable. Many vehicles and motorcycles can be tuned using the Moristech interceptor including Ford, Toyota, Holden, BMW, Chrysler, Mazda, Suzuki, Honda
