Stramvaier Skrevet Januar 8, 2012 Skrevet Januar 8, 2012 Selger en helt ny Åndetank fra 034Motorsport. Denne er av typen Vortex design, den er laget med ordentlig skille innevendig mellom olje og dampen. Selges da den blir for liten for min motor. Litt om tanken: 8" tall, 3" diameter, holds .25 gallons or about 1 liter. Large 1" inlet and outlets for free breathing. 1/4" NPT outlet drain. Vortex design means incoming gasses hit round cylinder wall being forces to spin in a "vortex", centrifugal force causes oil and water particles to fling outward and drain down the walls to be collected or returned to the sump. The outlet on the can extends down 4" inside the can to create a baffle and prevent incomming fluids to being expelled directly out the can. This breather can is recommended for all high performance applications to remove oil vapor from the intake tract. Denne er helt ny, og ubrukt. Selges for kr 1000 ,- pluss frakt.
Stramvaier Skrevet Januar 18, 2012 Forfatter Skrevet Januar 18, 2012 Bump. Ingen som trenger grom tank til turbo prosjekte sitt?
