glennytail Skrevet April 11, 2012 Skrevet April 11, 2012 2stk Kenwood KFCW3013 12" subber i lukka kasse selges! 400rms! Selges for 1500kr før helja! Bilder Spesifikasjoner:300mm P.P.Cone with fiber texture Diamond Array Diaphragm 1200W Maximum Input Power Dual Ventilation System Rubber surround Push Terminals Reversible gasket Høyttaler: Speaker Type: Subwoofer Peak Input Power 1200W Rated Input Power 400W Speaker Size 300mm Speaker Cone Design Diamond-Array pattern Magnet Type Ferrit Terminals Silver-plated Push Type Dual Ventilation System Yes Speaker cover Yes, as part of dual ventilation system Gasket Installation two-sided Installation Capabillity Sealed/ Ported Høyttalerspesifikasjoner: Peak Input Power 1200W Maximum Input Power 800W Rated Input Power 400W Woofer Cone material Injection P.P. Cone Speaker Basket Steel Speaker Surround Rubber Sensitivity 85dB/W/m Frequency Response 34Hz ~ 300Hz Subwoofer Impedance 4Ω x 1 Dimensions (W x H x D) 326 x 326 x 170.5mm Mounting Depth 153mm Mouting Hole Diameter Ø 282mm Speaker Weight 6300gr Weight of Magnet 1780gr Subwoofer Parameters: Nominal impedance (Z) 4Ω DC resistance (Re) 3.4Ω Resonant frequency (FSO) 25Hz Mechanical Q factor (QMS) 8.25 Electrical Q factor (QES) 0.91 Total Q factor (QTS) 0.82 Voice coil inductance (LBM) 1.65mH Voice coil diameter (d) 65mm Force factor (BL) 10.5T/m Peak excursion Xmax 15.1mm Moving mass (MMS) 183gr. Volume accoustic compliance (VAS) 83.7liter Piston Area (SD) 0.051m² Displacement 2155cc Sealed box volume 35.4liter Sealed Box Dimensions 475 x 362 x 299mm ( 19mm thick MDF)(WxHxD) Vented box volume 56.6liter Vented Box Dimensions 590 x 362 x 355mm ( 19mm thick MDF)(WxHxD) Port dimensions (labyrinth) (W x H x L) 38 x 324 x 546mm
