stoptech bremser til salgs. 355 mm calipper.
stoptech bremser til salgs. 355 mm calipper. til e36 m3 nypris 25000++
sorte calippere. følger med nye klosser(yellowstuff) bør ha et sett med nye skiver.
bud
  • 8 months later...
Det er i orden. Fått tilbud på nytt til 10-11 tusen, og da er alt nytt, inkl skiver og, i mine øyne, bedre Klosser. Hva ønsker du deg?
StopTech Front & Rear Big Brake Kit (355mm) - E36 M3
Part #: 83.131.4746
Position: Matching Front and Rear
Caliper: 4-piston ST40 (front and rear)
Colors: black, red, silver, blue, yellow, custom (call)
Front Rotors: 355x32mm, cross-drilled or slotted
Rear Rotors: 332x32mm, cross-drilled or slotted
Also Included: stainless steel brake lines, StopTech Street Performance pads, hardware
StopTech Brakes puts championship-winning race technology and state-of-the-art engineering under your feet. StopTech's Front and Rear Big Brake Kit for the E36 M3 is a model-specific brake upgrade engineered to work with the stock brake hydraulics and ABS/DSC system. StopTech builds each kit around the specific vehicle, engineering the system to achieve the correct brake balance. This brake upgrade gives better stopping performance in everyday driving, aggressive street driving, or all-out track days. By increasing the rotor size, using a larger pad, and a fixed forged aluminum caliper, you can improve your braking performance substantially for any condition! StopTech Brakes have been used on Turner Motorsport racecars since 2003, winning 5 sports car championships and recording numerous race wins since.
Safety Improvements from A Big Brake Kit:
+ Caliper design improves brake application and increases torque - braking is stronger meaning shorter stopping distances and faster response
+ Vehicle-specific design - improves brake feel with a firmer pedal
+ Larger and thicker rotors - less fade and longer pad and rotor life
Advantages of a StopTech Big Brake Kit:
+ extremely strong caliper and mounting system - reduces flex and deflection, improving torque application to the disc
+ Several color options available
+ Vehicle-specific calipers that maintain correct brake proportioning and balance
+ AeroRotor patented vaning for superior air flow
+ Cross-Drilled for street use or Gas-Slotted for street or track use
+ Billet aluminum mounting hats for superior strength over steel
+ DOT-compliant stainless steel brake lines
+ Street Performance brake pads that work on both street and light track use
Maximizing brake efficiency by braking with all four wheels... Sounds obvious right? Many bolt-on caliper upgrades and other big brake kits are not built with the specific vehicle's dynamics in mind. With too much braking force on the front, rear traction is compromised. And vice-versa. Brake traction is better when all four tires are doing the work. Most BMWs have 50-50 weight distribution so the correct braking proportioning is crucial! StopTech engineers each kit around that vehicle's dynamics by altering the size and number of pistons in the caliper to match the rotor size used in the kit. Bigger is not always better...
Brake FAQs
Brake Pad Buying Guide
Brake Rotor Buying Guide
Wheel Fitment Guides: Wheel spoke-to-brake caliper clearance is critical since the new caliper is physically larger and the in a different position. StopTech has produced these cutaway diagrams for you to print and place on the backside of your wheel to check for clearance. Wheels that do not clear will need a wheel spacer. The minimum recommended clearance between the wheel and caliper is 3mm.
E36 M3 - front 4-piston/355mm rotor
E36 M3 - rear 4-piston/332mm rotor
StopTech E36 M3 Brake Kit Applications:
1995-1999 E36 M3, including coupe, sedan, and cabrio models
We will meet or beat any advertised price for StopTech Big Brake Kits! Call or e-mail us with the published pricing that you found and we will do our best to not only match that price but actually beat it!
Select Product Options:
*Select your Brake Kit options:
Black calipers, slotted rotors (83.131.4746.51)Black calipers, drilled rotors (83.131.4746.52), Add $200.00 (USD)Red calipers, slotted rotors (83.131.4746.71)Red calipers, drilled rotors (83.131.4746.72), Add $200.00 (USD)Silver calipers, slotted rotors (83.131.4746.61)Silver calipers, drilled rotors (83.131.4746.62), Add $200.00 (USD)Any other color (you will be contacted), Add $400.00 (USD)
*Choose brake pads:
StopTech Street Performance (standard)Hawk HPS street (HB141F.650), Add $243.90 (USD)Hawk Ceramic street (HB141Z.650), Add $283.20 (USD)Pagid Dark Blue Sport street ( U1204(S) ), Add $395.90 (USD)Hawk HP Plus track (HB141N.650), Add $329.90 (USD)Pagid Orange race (U1204/RS4-4), Add $453.90 (USD)Pagid Black race (U1204/RS14), Add $478.00 (USD)Pagid Yellow race (U1204/RS29), Add $619.90 (USD)Hawk HT10 race (HB141S.650), Add $351.90 (USD)Hawk 9012 Blue race (HB141E.650), Add $162.95 (USD)
Base Price: $4,899.95 (USD)
Customized Price: $4,899.95 (USD)
Please select the available options below, then click show customized price to enable the Add to Cart / Add to
Altså 28000 + frakt og moms fra usa, men du kan jo bare fortsette å drømme at du får samme sette for 10-11 XD
Det er foran og bak.. :wink: Etter hva jeg forstår av din annonse, så selger du kun foran?
Edit; sjekket mailtilbudet jeg har fått, og husket feil. Prisen var 14-15, men da med ordentlige bremseklosser.
Hva ønsker du å selge de for? Har enda ikke fått noen konkret pris..
Nei, det har jeg skjønt at du ikke vil selge for, men hva ønsker du deg? Klossene trenger jeg evt. ikke, hvis det skulle hjelpe på prisen for min del. Hadde vært fint med bilder av de aktuelle delene også. Har du det?
