prøvde å legge in en video snutt her men.. har en bmw E38 v8 3,0 l som uler voldsomt på tomgang. når jeg tar opp peile pinnen stopper den. også begynnerden når jeg setter den ned igjen.noen som vet hva som er galt da????. ryker ikke noe spes.
Høres ut som innsugsmembranen. står i bakkant av innsug.
http://www.howto-make.org/Mw3RtMoney8NeNKk/BMW-E38-7-and-5-series-E39,-M60-M62-M62-TU-REAR-OSV-(membrane)-swap-in-10-minutes.html
Kan naturligvis være OSV også, men det er skjeldnere man hører om, samt uforskammet mye mere jobb å fikse.
http://www.ecstuning.com/Search/Dipstick_Tube/ES19611/
En OSV erfaring:
I had the OSV fail on my car a few months ago and I can tell you that it smokes all the time, not only at start-up.
One way to tell is to pull the dipstick when the engine is running, and if the OSV has failed you can hear a sucking noise (mine was so bad I actually struggled too pull the dipstick off).
Changing the part is a PITA due to the valves position but saves a lot of money compared to going to a garage.
