Alexbre Skrevet September 22, 2015 Skrevet September 22, 2015 (endret) Problemet fikset! Måtte reattache radioenen for at "set caution alarm" skulle dukke opp. Endret September 24, 2015 av Gawdzilla
D.Toft Skrevet September 22, 2015 Skrevet September 22, 2015 det er en innstilling i menyen. men husker ikke hvordan
wicky124 Skrevet September 23, 2015 Skrevet September 23, 2015 Er vel bare for at du skal ta av skjermen på den for å unngå tyveri...
danskiii Skrevet September 23, 2015 Skrevet September 23, 2015 Er vel bare for at du skal ta av skjermen på den for å unngå tyveri... Helt korrekt.
Lars Frøysa Skrevet September 23, 2015 Skrevet September 23, 2015 Switching the warning tone: If the front panel is not detached from the headunit within five seconds of turning off the ignition, a warning tone will sound. You can turn off this warning tone. 1 Press FUNCTION when head unit off. Press repeatedly until FUNCTION appears in the display. 2 Select WARN Pressing 5/∞ will switch and off and that status will be displayed
Alexbre Skrevet September 24, 2015 Forfatter Skrevet September 24, 2015 Er vel bare for at du skal ta av skjermen på den for å unngå tyveri... Switching the warning tone: If the front panel is not detached from the headunit within five seconds of turning off the ignition, a warning tone will sound. You can turn off this warning tone. 1 Press FUNCTION when head unit off. Press repeatedly until FUNCTION appears in the display. 2 Select WARN Pressing 5/∞ will switch and off and that status will be displayed Har da detacha stereoen, og kun etter det kom option på general som sa "set caut alarm". Problemet LØST!. Slipper endelig å "rømme" fra bilen hver gang etter en tur.(Går virkelig på nerver etter nærmere snart et år) danskiii reagerte på dette 1
