02 Touring
Alt skrevet av 02 Touring
  1. Mekonomen KR 546,00
  2. Når det blir slitt. Det er ingen serviceinterval på det.
  3. O.K. På mine er det Tectyl bare under. Prøv med Bensin, "det er ikke fleip" Dynk ei fille klissvåt og la den ligge på tectylen.
  4. Haynes ligger her Ca 7 mb http://www.velom.net/bimmers/haynes_e30_e28_e34.pdf Og du kan doble prisen til Fliid. Mekonomen skal ha 943,00 for Registerreimsats.
  5. Har du E34 520 nyere enn 01/91 så er det samme diff. (Med M50 motor) De fra M20 motor passer de også men de utveksling på 1:4,44 Part Cross-reference Part 33101213705 (RMFD FINAL DRIVE) was found on the following vehicles: E34: Details on E34 E34 518g TOURING, Euro E34 518i SEDAN, Euro E34 518i TOURING, Euro E34 520i SEDAN, Euro E34 524td SEDAN, Euro E34 525td SEDAN, Euro E34 525td TOURING, Euro Details for all
  6. Hvor sto det at det var inne i bilen??
  7. Stiming elller høytrykk med varmt vann
  8. Lever den tilbake på verksted snarest. Havari er DYRT.
  9. 02 Touring
    vekt e36
    Ja BMWCCN http://www.bmwccn.no/nor/kapittel1/m/mbilene_m3.htm
  10. ONLY APPLIES TO DRUM BRAKE 01 TRAILING ARM, LEFT 1 33321090449 $778.41 01 TRAILING ARM, RIGHT 1 33321090450 $778.41 Part Cross-reference Part 33321090449 (TRAILING ARM, LEFT) was found on the following vehicles: E36: Details on E36 E36 316i COUPE, Euro E36 316i SEDAN, Euro E36 318i SEDAN, Euro E36 318tds SEDAN, Euro Details for all
  11. Bruk Online ETK Part Cross-reference Part 33326774778 (TRAILING ARM, RIGHT) was found on the following vehicles: E36: Details on E36 E36 316i SEDAN, Euro E36 316i COUPE, Euro E36 318i SEDAN, Euro E36 318is SEDAN, Euro E36 318is COUPE, Euro E36 318tds SEDAN, Euro E36 320i SEDAN, Euro E36 320i COUPE, Euro E36 323i SEDAN, Euro E36 323i COUPE, Euro E36 325i SEDAN, Euro E36 325i COUPE, Euro E36 325td SEDAN, Euro E36 325tds SEDAN, Euro E36 328i SEDAN, Euro E36 328i COUPE, Euro E36 316i TOURING, Euro E36 318i CONVERTIBLE, Euro E36 318i TOURING, Euro E36 318tds TOURING, Euro E36 320i CONVERTIBLE, Euro E36 320i TOURING, Euro E36 323i TOURING, Euro E36 323i CONVERTIBLE, Euro E36 325i CONVERTIBLE, Euro E36 325tds TOURING, Euro E36 328i TOURING, Euro E36 328i CONVERTIBLE, Euro E46: Details on E46 E46 316Ci COUPE, Euro E46 316i TOURING, Euro E46 316i SEDAN, Euro E46 316i 1.6 SEDAN, Euro E46 316i 1.9 SEDAN, Euro E46 316ti COMPACT, Euro E46 318Ci CONVERTIBLE, Euro E46 318Ci COUPE, Euro E46 318d SEDAN, Euro E46 318d TOURING, Euro E46 318i TOURING, Euro E46 318i SEDAN, Euro E46 318td COMPACT, Euro E46 318ti COMPACT, Euro E46 320Cd COUPE, Euro E46 320Cd CONVERTIBLE, Euro E46 320Ci CONVERTIBLE, Euro E46 320Ci COUPE, Euro E46 320d SEDAN, Euro E46 320d TOURING, Euro E46 320i TOURING, Euro E46 320i SEDAN, Euro E46 320td COMPACT, Euro E46 323Ci COUPE, Euro E46 323Ci CONVERTIBLE, Euro E46 323i SEDAN, Euro E46 325Ci CONVERTIBLE, Euro E46 325Ci COUPE, Euro E46 325i TOURING, Euro E46 325i SEDAN, Euro E46 325ti COMPACT, Euro E46 328Ci COUPE, Euro E46 328i TOURING, Euro E46 328i SEDAN, Euro Details for all Search another part: Enter 11-digit or 7-digit Part Number: U.S. Euro Home Copyright © realoem.com.
  12. Han lager det meste http://www.runehansenmotorsport.com/
  13. Blokka er den samme. http://www.realoem.com/bmw/partxref.do? ... showeur=on Men bunnpanne og oljesil må byttes.
  14. Det er 2 skruer (nr17) http://www.realoem.com/bmw/showparts.do ... g=62&fg=05 så vipper du det fram i overkant, drar det ut så du får plass til handa.tar av koblinger, Det er mulig du må ta av rattet! På min går det ved og bra ratsammen helt ut og vri på rattet. (justerbar rattstamme)
  15. Ta av reima på servopumpa, er lyden borte? Blir den ikke borte? Da er det noe annet.
  16. Motoren er S52 http://www.realoem.com/bmw/select.do?vi ... s=M&arch=0
  17. Bruk binders.
  18. Du har en motor som kommer fra en E28 (520) http://www.realoem.com/bmw/showparts.do ... g=11&fg=25
  19. 525i E 12 og E28 har alltid hatt M30 motor . 525E hadde M20. og 3 serien har M20
  20. Det ligger noe data om olje kvanta på denne linken http://www.bmw-z1.com/VIN/VINdecode-e.cgi
  21. Kosteskaft. Spiss det som en blyant i enden, bruk tape der lamella skal stå. P.S. Det går og kappe skaftet osgå.
  22. Bruk 3M cleaner spray (Sitrus Rens) på limrestene. Det virker.
  23. Dere trenger melomaksel. svinghjul, lager i veivaksel, gearspag med overføring. og mulig en ny konsoll. Ta et søk i forumet så finner dere enda mer.
  24. Sveis på en mutter.
