In-tank fuel pump or transfer pump
14 On some models, access to the fuel pump
is gained by removing the rear seat cushion.
On other models, access is gained by
removing the carpet from the luggage
compartment.
15 Remove the screws from the fuel pump
access cover (see illustration).
16 Remove the cover.
17 Locate the fuel pump and sender unit
electrical connectors (see illustrations) and
unplug them. Also, disconnect the fuel inlet
and return lines.
18 On some models, the assembly must be
rotated anti-clockwise to disengage the
locking lugs from the fuel tank (see
illustration). On other models, the assembly
is secured to the tank with nuts (see
illustration). Carefully lift the assembly from
the fuel tank (see illustrations). It may be
necessary to twist the assembly slightly, to
get the float to clear the opening.
19 On early models, remove the transfer
pump mounting screws and clamps, and
separate the transfer pump from the
assembly.
20 Refitting is the reverse of removal. If the
gasket between the fuel pump and fuel tank is
dried, cracked or damaged, renew it.
I følge haynez
