Har 2 kicker forsterkere jeg tenker på opg kvitte meg med, da det ikke blir noe nytt anlegg på meg med det første.
Kan sendes mot forskudsbetaling.
Nr.1
Kicker ZX.1500.1
Fra Kicker.com
Model ZX1500.1
Class D
Power (watts) Mono 1500 @ 2 Ohms
Remote Bass Control Yes
Length (in.,cm) 20, 50.7
Height (in.,cm) 2-1/8, 5.4
Depth (in.,cm) 9-5/8, 24.4
Frequency Response 25Hz-200Hz, +0, -1dB
Input Sensitivity (High Level) 250mV-10V
Input Sensitivity (Low Level) 125mV-5V
Signal-to-Noise Ratio >>95dB, a-weighted, re: rated power
Active Crossover 24dB/octave, variable 50Hz-200Hz, low pass only; 24dB/octave high-pass subsonic filter fixed at 25Hz
KICKEQ Boost Variable to +18dB, centered @ 40Hz
12dB/octave Subsonic Filter defeatable @ 25Hz (ZX300.1 fixed @ 25Hz)
Differential RCA inputs eliminates unwanted system noise
Automatic Turn-On Modes +12V (Remote) - preferred method; uses the remote turn-on lead from source unit; DC Offset - detects surge from hi-level speaker outputs after source unit is turned on; Audio (Signal Sense) - detects audio signal from source unit
Nr.2
Kicker ZX 650.4
Model ZX650.4
Power (watts/channel) 2 Ohm Stereo 170 x 4
Power (watts/channel) 4 Ohm Bridged Mono 325 x 2
Frequency Response 20Hz-20kHz, +0,-1dB
Signal-to-Noise Ratio >95dB, a-weighted, re: rated power
Active Crossover 12dB/octave, variable 50Hz-200Hz; selectable high, low or all pass
Har også en dobbel 12" kasse med subber fra kicker
Model DCVR12
Type Dual
Impedance (OHMS) 2 or 4
Woofer CVR12 x2
Max Rec Amplifier Power (WATTS PEAK/RMS)* 1600/800
Dimension A (in., cm) 13-15/16, 35.4
Dimension B (in., cm) 17-3/8, 44.1
Dimension C (in., cm) 16, 40.6
Dimension D (in., cm) 32-1/2, 82.6
*Assumes typical music program with minimal amplifier clipping; varies with enclosure size. See your KICKER dealer for details.
Bud Ønskes.
