Plumbo
25 -
Alt skrevet av Plumbo
Hei Det du har målt no er forbindelse mellom ABS pumpe og ABS Hjernen. På denne modellen sitter ABS hjernen under dashbordet på passasjerside. Her kan du måle forbindelse mellom hjerne og hver enkelt sensor. Ovesikten over kontaktpinnene fra hjernen: Pin Type Description / Signal type Connection / Measuring notes 1 E Voltage supply, terminal 15 Terminal 30 voltage supply Fuse F17 DDE Fuse F31 DME 2 A Valve control Hydraulic unit, Left front inlet valve Relay control 3 A Relay control Valve and motor relay 4 Not used 5 Not used 6 A Valve control Hydraulic unit, Right rear inlet valve Relay control 7 A Relay control Motor relay 8 Not used 9 A Engine speed signal Left front wheel speed splice 10 A Engine speed sensor voltage supply Left front speed sensor 11 E Engine speed sensor signal Right rear speed sensor 12 A Engine speed sensor voltage supply Left rear speed sensor 13 E Engine speed sensor signal Left rear speed sensor 14 A Engine speed sensor voltage supply Right front speed sensor 15 E Engine speed sensor signal Right front speed sensor 16 Not used 17 Not used 18 A Increase idle speed signal Engine control module (DME) 19 E B+ power/feedback Engine control module relay, terminal 87 20 Not used 21 Not used 22 Not used 23 A Voltage control Auxiliary throttle position motor (ADS) DME 24 E Generator signal Generator control splice DME 25 A Valve control Hydraulic unit, Left rear outlet valve 26 A Valve control Hydraulic unit, Intake valve 27 A Valve control Hydraulic unit, Right front outlet valve 28 M Ground Ground point 29 M Ground Ground point 30 A ABS malfunction indicator lamp Instrument cluster 31 A ASC malfunction indicator lamp Instrument cluster 32 Not used 33 A Valve control Hydraulic unit, Left front outlet valve 34 A Valve control Hydraulic unit, Right rear outlet valve 35 E Engine speed sensor signal Left front speed sensor 36 A RH rear engine speed signal Transmission control module (AGS) 37 A Relay control Valve relay 38 A Engine speed sensor voltage supply Right rear speed sensor 39 M Component ground ASC throttle position sensor DME 40 A LH rear engine speed signal Left rear wheel speed splice 41 Not used 42 A RH front engine speed sensor Right front wheel speed splice 43 A Throttle position sensor voltage supply ASC throttle position sensor DME 44 E ASC passive sensor signal ASC/DSC switch 45 Not used 46 E/A Data link TXD Data link connector 47 Not used 48 E Brake signal Brake light switch 49 A Valve control Hydraulic unit, Changeover valve 50 Not used 51 E Throttle actuator terminal 30 voltage supply Fuse F8 DME 52 A Valve control Hydraulic unit, Left rear inlet valve 53 A Ground control Auxiliary throttle position motor (ADS) DME 54 A Valve control Hydraulic unit, Right front inlet valve 55 M Ground Ground point 56 Not used 57 Not used 58 Not used 59 Not used 60 Not used 61 E/A CAN-bus high Engine control module (DME) 62 Not used 63 E/A CAN-bus low Engine control module (DME) 64 Not used 65 Not used 66 Not used 67 E Throttle position sensor slider voltage ASC throttle position sensor DME 68 Not used 69 Not used 70 Not used 71 Not used 72 Not used 73 Not used 74 Not used 75 Not used 76 E Park brake signal Park brake switch 77 A Ignition timing signal Engine control module (DME) 78 Not used 79 Not used 80 Not used 81 A Ignition fade-out signal Engine control module (DME) DME 82 Not used 83 A Transmission influencing signal Transmission control module (AGS) DME 84 A Power Hydraulic unit DDE Hydraulic unit 85 Not used 86 Not used 87 Not used 88 E DKI signal Engine control module (DME) DME Bare ta av kontakten på ABS hjernen og mål mellom: 10 og 35 venstre forran 11 og 38 høyre bak 12 og 13 venstre bak 14 og 15 høyre forran Dersom det er like verdier her er sensor og ledningsnett ok. Da kan det være dritt på sensor eller hjerne som har røket. Håper du finner ut av dette
ABS hjerne til e39 selges. Dette er til de første modellene som har ABS hjernen plassert under dashbordet på passasjersiden. Er plugg and play, trenger ingen koding. Dele nr: 34521164130 Tenkte rundt 1200kr for denne
Hei Er det noen som vet om det er fjæret eller stum clutch lamell i en e36 325td?
Hei Lurer på hvorfor rør til slavesylinder går i en spiral slik som dette: https://www.koed.no/2.5.asp?kbnummer=1048072&menulinkid=297&soegeord=
Hvordan sjekket du forbindelse mellom hjerne og ABS føler??
Hei Ønsker å kjøpe lamell til e36 m3 eller 325tds, 228mm
Hei ABS og antispinn lampen lyser på min e39. Når jeg tar singel diagnose av ABS med Carsoft 6.5 går det ca 5 sekunder så kommer det frem en melding: "det har oppstått et alvorlig problem og windows måtte stenge for å unngå skade", så slår PCen seg av. Har prøvd dette med to forskjellige PCer med samme resultat. Har brukt Carsoft noen ganger før og da har det fungert helt fint. Slår seg ikke av når jeg tar diagnose av andre ting. Har noen vert borti dette problemet før?
Ja, mente selvfølgelig støttestagene nr. 6 på bilde http://nettbutikk.gsbildeler.no/openIma ... /11193.gif
Hei Var på EU kontroll i dag og fikk noen manger jeg lurer på hva er. 5.2 slakk ytre nedre bærearmsopplagringer h/v bak Vet at "knirke" foringene er gåen bak, kan det være dette? 5.4 slakk ytre stab.stagkuler h/v foran og v/ bak Er dette stabilisator stag?
Hei Ønsker å kjøpe en rustfri bakluke til e39 sedan, helst med fargen 309 arktissilber met. Mvh. Daniel
Bmw e30 med M5 motor fra E34 selges Riger styling Pris 30 laken Ikke min bil så ring for info 95479419
Stemmer det, var det en mørk e46? Ja, snøen forsvant fort!
Bildene er tatt hjemme ja, på toppen av bontveit
Var nok ikke på safarien på tirsdag, men det hender jeg turer oppom der
Har hatt deltidsjobb og sommerjobber i en del år nå, så pengene kommer derfra Fikk bilen relativt rimelig da
Takker for positive svar!
Heisann Tenkte det var på tide å slenge ut noen bilder av første bilen min. Litt info om bilen: 1996 mod. 520i, manuell km. 190000 Importert fra Tyskland i 2000 Ting jeg har gjort med bilen: Nye lykteglass rundt om Nye felger; rondell D58 17" Svart facelift grill Liker egentlig bilen som den er, men hadde gjort seg med en liten senk. Selvfølgelig hadde det gjort seg med M rundt om, men jeg går på skole så har ikke så mye å bruke på bil.
Hei Langlyset på høyre side lyser hele tiden, selv når bilen er parkert. Får ikke opp noen feilmeldinger med carsoft. Har bare nappet ut kontakten forran til langlyset så den ikke tapper strøm. Noen som har peiling på hva dette kan være??
Hei Tok diagnose med carsoft og der kom det fram at 22 Auxiliary fan relay var gåent. Noen som har peiling på hvor det releet sitter? Har sett bak i bagasjerommet og i E-boksen under pollenfilteet men fant det ikke. Ser i Haynens at det skal være releer i hanskerommet der med sikringene men jeg har ikke funnet noen. Noen som vet?
Hei Min 520 e39 er veldig tung på rattet i perioder. Var slik for ca en måned siden, så ble den helt normal men nå det kommet tilbake. Servo olje nivå er ok, men den lekker litt (svetter) ved begge slangene ut fra sevobeholderen. Hører ingen ulyder fra servopumpe. Noen som vet hva dette kan være? er forøvrig en 1996 modell, som er gått ca 190000 Takker for svar
Hadde samme problem på min 520 e39, da var det ene ventilen til varmtvannet til varmeapp. som hadde tatt kvelden. På min bil går det tre aul. rør inn i bilen med varmtvann, disse ligger under en plate under rattet, kjenn på de og dersom en er mye kaldere enn de andre er det nokk ene ventilen som er konstant stengt. Vet ikke om det er samme på din bil, men det kan være. ventilene m/pume ser slik ut
Hadde samme problem med min, bare at det var på førersiden. Det var ventilen som styrer vannet til varmeapp. som var ødelagt. Skrudde av platen som er over beina (under rattet). Der kommer det tre aul. rør, kjenn på disse og dersom ett av disse er kaldt er det ventilen som det er noe gale med. Ventilen ligger under panseret ved venstre framskjerm. Jeg skrudde av ventilen (eller ventilene, sitter to ventiler som henger sammen der), og det viste seg at fjæren på spolen til ventilen var borte så jeg satt på en ny og nå funker den.
