raveman
Alt skrevet av raveman
  1. syntes du burde ha den som den er finnes ikke noe fetere en e46 coupe i sølv
  2. Takker
  3. var på service for et par dager siden det ble fylt på med bmw orginal olje 0w 40 er dette riktig? har hele tiden hørt 0w 30
  4. Orion 2500D Class D Mono Block Amplifier Power 13.8V Briged Power 1 X 1200 RMS 4 Ohm Briged Power 1 X 1700 RMS 2 Ohm Briged Power 1 X 2500 RMS 1 Ohm * Selectable 12/24 dB/octave variable low-pass filter * Intelli Q bass optimization circuit and remote gain option * Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs * Copy/Master feature supports gain and crossover adjustment matching in multiple amp * Allows external bridging of two matched gain amplifiers (models 600D and 1200D only) * Switchable phase invert function * Heavy gauge direct-wire high current satin finish power and speaker terminals Dimensions: 27.2"L x 10.5"W x 2.3"H Orion 2500D nypris 15 000 selges for 3000 http://www.finn.no/finn/torget/tilsalgs ... e=35970531
  5. Nei fusker akorat like mye som før
  6. Fikk for litt siden opp motorfeil lampe har akorat byttet alle coilene. Har tatt en diagnose test fikk opp flere feil bmw mente at det var nox sensor som var gåen ? kostet 4000 noen som har vært borti dette før ? bilen er en e92 320 i coupe 2007mod
  7. Orion 2500D Class D Mono Block Amplifier Power 13.8V Briged Power 1 X 1200 RMS 4 Ohm Briged Power 1 X 1700 RMS 2 Ohm Briged Power 1 X 2500 RMS 1 Ohm * Selectable 12/24 dB/octave variable low-pass filter * Intelli Q bass optimization circuit and remote gain option * Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs * Copy/Master feature supports gain and crossover adjustment matching in multiple amp * Allows external bridging of two matched gain amplifiers (models 600D and 1200D only) * Switchable phase invert function * Heavy gauge direct-wire high current satin finish power and speaker terminals Dimensions: 27.2"L x 10.5"W x 2.3"H Orion 2500D Pris 5000 Kicker L7 Pris 3000 Selges helst samlet
  8. Har en bmw e36 320 som jeg skulle ha skiftet girkassen å tannstagen på men har ikke løfte bukk blir for tungvint å ligge under så hvist noen i kristiansands området kunne tenke seg å gjøre dette så er det bare å si ifra betaler selfølgelig
  9. Ser ut som et bra prosjekt dette her men hvor er det du skal lakkere bilen hen ?
  10. Takker for svar skal ned å se på det nå er ikke jeg som har montert potta var montert når jeg kjøpte bilen
  11. Skulle til å montere mine nye hartge replica felger i dag 8.5X18" men felgen tar borti bakpotta (supersport) er snakk om ganske mye så går vel ikke akorat med spacere noen som har hatt dette problemet ?
  12. raveman
    fikset
    Tror nok det blir ny motor da er sikkert det enkleste
  13. raveman
    fikset
    fikset
  14. passer disse e36 ?
  15. Nei skjer selv om det er full tank
  16. Har et problem med min 320 hvist jeg kjører hardt i en sving eller rundkjøring så kutter motoren i et eller to sekunder før den kommer seg igjenn Noen som har noen ider om hva som kan være feil ?
  17. bump
  18. Har fått lekkasje i bensintanken på min 320 e36 spørsmålet var da om det er mye jobb å ta ned tanken eller om det er mulig å bytte slanger uten å ta den ned, har sjekket bensinpumpene ikke noe lekkasje der Tanken er foresten av plast
  19. Noen som kan forklare hvordan man monterer dette ?
  20. Kraftig 4 kanalers Solid Audio F47 forsterker selges nypris 5000 Output Powers: • 160W (RMS) x 4CH (2 Ohm) • 100W (RMS) x 4CH (4 Ohm) • 260W (RMS) x 2CH (4 Ohm) • 300W (max) x 4CH (2 Ohm) Dim: 9.54W x 2.13H x17.72L Selges for 1000 kr bare å ta kontakt om du er intresert tlf 41848161
  21. Skal snart til å bytte girkassen i min 320 er dette mye jobb, vanskelig ? Takker for alle svar
