ogis
Alt skrevet av ogis
  1. Jo det er det som slår meg og, har ikke kommet så langt att eg har gått over bilen endå tenkte ta litt teori først, men lurte på om det var noe nede på fjørbeina og å om det gikk på stab stabstagne under motor. men som du sier så virker det som det er toppen av dempertårna ja og disse stagene
  2. Har fått en knirke/knake lyd i bilen som virker som det kommer fra dashbordet? KAN DET VÆRE DETTE?? http://forums.5series.net/topic/45017-c ... dashboard/ SI B51 13 04 Body Equipment August 2007 Technical Service This Service Information bulletin supersedes S.I. B51 13 04 dated June 2007. designates changes to this revision SUBJECT Rattling Noise from Center Display MODEL E60, E61 (5 Series sedan and sports wagon) produced up to June 2007 E63, E64 (6 Series coupe and convertible) produced up to June 2007 SITUATION A rattling noise may be heard from behind the center display or lower windshield area when the vehicle is driven over bumps. CAUSE The retaining bolts for the cross strut brace on the center support bracket, or on the strut towers, have worked themselves loose. In some cases, the threaded holes of the aluminum center support bracket have become damaged. Full SIB Attached File SIB_511304.pdf (40.03K) Number of downloads: 134 Noen som vet ka de strammet her? dempertårna? noen som har en norsk forklaring??
  3. Har fått en knirke/knake lyd i bilen som virker som det kommer fra dashbordet? KAN DET VÆRE DETTE?? http://forums.5series.net/topic/45017-c ... dashboard/ SI B51 13 04 Body Equipment August 2007 Technical Service This Service Information bulletin supersedes S.I. B51 13 04 dated June 2007. designates changes to this revision SUBJECT Rattling Noise from Center Display MODEL E60, E61 (5 Series sedan and sports wagon) produced up to June 2007 E63, E64 (6 Series coupe and convertible) produced up to June 2007 SITUATION A rattling noise may be heard from behind the center display or lower windshield area when the vehicle is driven over bumps. CAUSE The retaining bolts for the cross strut brace on the center support bracket, or on the strut towers, have worked themselves loose. In some cases, the threaded holes of the aluminum center support bracket have become damaged. Full SIB Attached File SIB_511304.pdf (40.03K) Number of downloads: 134 Noen som vet ka de strammet her? dempertårna? noen som har en norsk forklaring??
  4. ler litt av deg her eg har det største hifi anlegget med den største forsterkeren bak og 15 høytalere. bra høy og fin lyd men alt for lite bass kom seg med 2x 10" heavy duty pioner subber baki samt en til svær forsterker med kondensator no ble det trøkk
  5. Er veil ikke værre en og hente styrestrøm fra baklyset e.l.? Sent from my GT-I9100 using Tapatalk 2 ja men hadde du lest lengre fram i tråden kan du ikke måle strømmen i kontakten så lenge den ikke står i stikket på lyset, virker som den kutter alt til kontakten når den ikke står i? skjønner? så spørsmålet er ka farge har ledningen til kjørelyset bak?
  6. til forsterker foreksempel? må ha en plass eg kan hente strøm fra i bagsjkerommet til styrestrøm til forsterker
  7. Opp igjen.. kor henter vi styretsrøm fra i bagsjerommet på en 530d 2004 modell e60
  8. Kan sjekke baklykta til en kompis av meg, er det en LCI utgave du har, altså er bilen produsert etter 03/2007 ? nei dette er en 530d 2004 modell e60 Men kansje fargene på ledningsnettet er det samme?
  9. Ja men vet ikke ka av ledningene på baklysa som er til kjørelys, å har ikke lyst å dra noen ledning fra stereoen det blir litt styr. målte ledningene i kontakten men de gir ikke signal så lenge kontakten ikke står i lyset virker det som så då fikk eg ikke målt de noen som vet ka farge ledmningene til kjørelys har bak på en e60 sedan
  10. Noen som vet kor eg kan hente styrestrøm fra i bagasjerommet? har koblet forsterker der bak å trenger styrestrøm. Går det å ta fra kjørelysa og ka farge har de ledningene eventuelt`??
  11. nesten ubrukt pumpe selges kr 600 div 3" skjøtestykker svarte og blåe og noe tynne samco vacum slanger selges
  12. gir deg 300 for tåkelysa med motstand
  13. er nok dyr frakt på denne vil eg tro men 800 pluss frakt å den er din tlf 46749019 vist noen vil ha den... er helt ny og koster over 2000 på koed
  14. Tr jo 20 sek vist du kan det:) Men modertator kan godt slette de useriøse innlegga mine for å holde tråden litt mer ryddig
  15. bilde kom i posten lenger oppe
  16. Bilde av nye felgene flere kommer med høyere kvalitet
  17. LOL fant ut av det.. trodde ikke vheicle chek menyen var så stor :/
  18. ok, får se i menyen då.. er den menyen det samme som IDRIVE? fikk inntrykk att det var 2 menyer for eg kan ikke stille hvordan bilen skal lyse når eg slår på alarmen i den vanlige menyen
  19. Vist det over ikke funker så hjalp det for meg å bare gå inn i menyen å trykke på set tyre pressure så gikk det vekk
  20. ok, ja hvordan kommer du inn i IDRIVEN? sitter å leser instruksjonboken no. Kjøre aldri rundt uten sentreringsringer men fikk felgene i dag uten ringer å måtte bare prøve den en tur kan du forklare meg hvordan du går inn i IDRIVEN? REGNER MED DET IKKE ER DEN VANLIGE MENYEN SOM DU BRUKER meny knappen for å bruke? casp lokken henger her
  21. Kan ikke nulstille noe dekk trykk i menyen NEI!!! har ikke det utstyret på bilen forstår ikke du det FIDEL CASTRO?? Men har tydligvis noe i varslingsystemet om att eg har punktert å eg vil tro det har med vibrasjonen å gjøre grunnet manglende sentering
  22. Har ikke det i menyen tror eg, hvordan går eg inn i IDRIVE?? Hvorfor tror du at du får opp punktert dekk, viss du ikke har slikt i menyen? Helt utrolig at du kan sitte forran PCen og trykke, og måtte vente i flere timer på svar. I steden for å sette deg i bilen og trykke i max 5 min, så har du trykket gjennom hele Idriven. RO DEG NED FIDEL CASTRO!!! har trykket gjennom hele menyen, men er det en skjult meny en plass det eg lure på? har ikke dekktrykk kontroll i utstyrslisten min eller runflat osv har og søkt i google med å holde inne kanppeni instrumentet men det funket ikke heller. bare spør her for eg har andre ting som er mer prioritert!!
  23. Har ikke det i menyen tror eg, hvordan går eg inn i IDRIVE??
  24. Får opp att dekket har punktert etter montering av 20" på min e60 ? har ikke sånn som måler dekk trykket orginalt mener eg.. tror det er vibrasjionen som utløste dette pga manglet sentrerings ringer foran!!! får ikke vekk varsellampen
