Sondrusen
43 -
Alt skrevet av Sondrusen
Det vet jeg ikke, for jeg har kun hatt bilen i 2 måneder Uansett hva det er så virker det ikke ut som ett type STORT problem. Bilen fungere jo meget bra ellers
Har ikke powerbox nei Eller noen form for trim på denne. Liten update, når jeg får den ujevne gangen, trenger jeg bare å ta gasspedalen inn 1 micromillimeter for det gir seg helt, å går som normalt.
Ingen svart røyk under pådrag, ingen dyselekasje heller. EGR skal jeg kjøpe bypass til.
Det kan være, men er mer sannsynlig at det ikke er. Den går jo helt fint fint uten ujevn gange når den er kald, det er når motoren er varm den tuller seg. Edit: Leste dette på ett forum, riktignok ett Porsche 944 forum. Men det kan være samme problemet. I think it is interesting that it runs fine and then starts stumbling. Does this only happen when the car is cold? For example if the car has been sitting overnight and you start it, it runs fine for a bit and then starts running rough, right? If you then turn it off and immediately start it again does it still run rough? If you answer yes to both of these problems, it sounds like the problem is temperature dependent. When the car starts cold, it ignores the input from the O2 sensor and runs off a predetermined fuel map with additional fuel to richen the mixture when cold. Once the motor reaches operating temp, measured from the DME temperature sensor, the DME leans out the mixture and tries to use the O2 sensor to manage the A/F ratio. That only leaves a couple of items to cause problems: 1. The DME 2. The O2 Sensor The DME temp switch shouldn't be the problem because that would cause it to run rough when cold, not warm. To test the DME, you'll need a spare to swap in. To test the O2 sensor, simply unplug the connection at the firewall. The only other suspect I can think of is the reference sensors. They can sometimes be sensitive to heat. Hmmm
Hei godtfolk, har ett lite problem med bilen. Når motoren er varm så går den litt ujevnt, men kun når den står i "P" Jeg ser for meg at det har med at batteriet er dårlig, for det vet jeg det er. Grunnen til jeg tror det er fordi når motoren er kald, går den fint, å det ser jeg for meg er pga den får mer diesel enn når den er varm. Det samme skjer når den står i "R" eller "D" Selvom bilen står i ro, å den gir jo litt mer diesel enn når den er i "P" (tror jeg) Er det noen som har tips, eller har opplevd dette før? Jeg har ikke ett multimeter
Takker og bukker Å det er mer krefter å hente
Jeg tenkte faktisk ikke noe på det, før det var forseint
Det har vært noen glade dager nå, fikk nemlig skilt på bilen min på torsdag Har nok fått SV nummer da -.-
Idag er en gledens dag, og forsåvidt forgårds og igår og. For da fikk jeg endelig norske skilt på bilen
Det høres ut som for mye diesel i forhold til luft ja, går bilen dårligere og/eller bruker den mer? Selv mener jeg at daukjørt bare er ett ord Den ene bilen min har passert 1,3 millioner. Å fungerer meget bra
Hos meg var det dårlig gjording på mercedesen som gjor det vanskelig. Fant ett bedre gjordingspunkt, å lot bilen få motta strøm i 10-15min, først da startet den. Hadde også det problemet at starteren ikke var sterk nok i begynnelsen
De var nice ja Offtopic, skal xenon'en i E38 kun virke so nærlys? Når jeg slår på langlys så er det kun halogen som lyser langt.
God kveld Jeg så på noen nye felger til bilen idag, å fant noen fine. Jeg har allerede 18" på bilen, og lurer på om jeg skal gå for noe større. Da tenkte jeg 19" eller 20". Jeg vil ha noen dekk som er gode å kjøre med, å hvis jeg velger 20" får jeg en dekk bredde på 305 bak, nokså heftig vil jeg si, å dette vil vel være skikkelig ukomfortabelt å kjøre med? Er det noen som har noen tips på hvilken størrelse og bredde jeg bør ha for å bevare komforten, men samtidig noen som henger godt på veien ? God helg
Her: viewtopic.php?f=6&t=239149
Helt enig Er megafornøyd med min første BMW Var absolutt ikke noe sinke på autobahn, 160-200 gikk helt av seg selv, selv i oppoverbakke
Du må betale full avgift som er ca det du regner ut på toll.no. Så har du 14 dager på å søke alternativ beregning. Alternativ lønner seg mest om bilen er eldre/mye hester eller høy km. Kan også lønne seg hvis bilen er en av få i Norge. På papirene må du skrive grundig hva du mener bilen er verdt i forhold til en som er på finn f.eks. Du kan også ringe en bilforhandler, som kan skrive at bilen ikke er mere verdt enn en viss sum. Det vil hjelpe deg tror jeg. Skal også ta alternativ på bilen min, og det vil antagentlig vis lønne seg for meg hvertfall. Uki Lønner seg nok for min del, er en del hester i en 740d, og det er ikke mange av dem i Norge, kan ikke huske sist jeg så en sånn til salgs i Norge I E38
Hei, jeg hentet meg en bil ifra Tyskland for ikke lenge siden, å jeg ønsker å ta den inn på alternativ beregning. Slik jeg har forstått det, Må jeg betale full engangsavgift, å så får jeg igjen pengene når det er regnet ut alternativ beregning, stemmer dette? Jeg har forstått at det finnes firmaer som kan hjelpe med å få den alternative beregningen uten å måtte betale den fulle engangsavgiften, er det noe som vet hvem disse er? Håper noen kan svare
Vel, 399kr er jo ikke noe spesielt dyrt om den virker. Virker den ikke eller er dårlig kan du alltid få pengene igjen Kjøp den så kan du gi oss tilbakemelding
Takk for det Det er også en utrolig pålitlig bil, her er det ikke mye som kan gå feil akkurat, å når det først gjør det, er det veldig lett å finne feilen.
Hei Jeg har en E38 med S-EDC dempere, jeg syns personlig at den er litt høy, og at den kunne hengt litt bedre i svingene. Jeg ser at Eibach selger ett sett med senkefjærer, som senker 30mm foran og 25mm bak. Vil dette slite veldig på de originale demperene? De påstår at de skal være lagd for EDC, men det tar jeg med en klype salt. Er det noen andre måter å senke den på?
BMW'en gikk tom for strøm for ett par dager siden, passet dårlig siden jeg skulle ta service på den, å jeg hadde ikke startkabler tilgjengelig. Fikk start på den idag da jeg endelig fant kablene mine, så nå lever den igjen Imorgen skal de taes motorens, bytte olje (9,5l ) og oljefilter. Til uken får jeg forhåpentligvis ny bærearm på høyre side framme, for der er det en foring som er gåen. Å forhåpentligvis dieselfilter og luftfilter.
Jeg fikk start på den!! Hurra Takk for hjelpen folkens
Jeg har ikke byttet batteriet, det ser egentlig ganske så nytt ut og. Kan batteriet bli ødelagt når sånn skjer ? Jeg skal prøve igjen litt seinere idag, men syns det er litt rart at ikke starteren engang lager lyd. Men så er det såvdit jeg ser fargene i speedometeret når kablene ble tatt av. Så holdt jeg ikke så lenge på heller.
