S42B20 - Den ultimate maskin (e36 320 STW)
BMWsideways
Hei tenkte jeg skulle legge ut noen bilder og litt info om denne motoren og om bilen den sitter i (320 STW).
S42B20 (Version: 08/1995):
* Stroke = 85mm
* Bore = 86.5mm
* Compression ratio = 12.4:1
* Total displacement = 1.997ccm
* Rod length = 145mm
* Inlet cam = 312 degrees (spread: 94) (Eö=40, Es=48 (@ 2mm lift) )
* Exhaust cam = 304 degrees (spread: 98) (Aö=45, As=28 (@ 2mm lift) )
* Inlet Valve diameter = 35mm
* Exhaust valve diameter = 32mm
* Inlet port metrics: W=52mm, H=29.7, Radius=14.85mm
* Slide throttle diameter = 46mm
* Header = 4-2
* ECU = ECU4A.1
* Power DIN 70020 = 285PS / 207kw @ 8300rpm
* Torque DIN 70020 = 245Nm @ 7000rpm
* Max rpm = 8500rpm (FIA regulation "SuperTouring")
* Gasoline quality = Super Plus (Oktan min. ROZ 98)
