denne Z4`n vil jeg ha!
"The Motorsport Version of the BMW Z4 M Coupé, which has already made a big impression as a production model, is the first two-seater BMW Motorsport offers for customer teams. When it came to the development, BMW faced a huge challenge: The car had to have what is needed to race successfully on the world's most demanding and spectacular racetrack, the Nürburgring's famous Nordschleife. The new motorsport coupé can be used by private BMW customer teams in the German Endurance Championship and in the Nürburgring 24-Hour Race.
The power unit of the beefy coupe is a BMW Motorsport designed 3.2-litre in-line 6-cylinder engine delivering about 400bhp, with the suspension area in particular benefiting from the knowledge gained from the successful BMW M3 GTR project.
The kit can be ordered from May 2006 at BMW Motorsport and will be available for an estimated Euro 250,000 (plus VAT).
With its varied component ranges, BMW Motorsport and BMW Racing Parts Distribution offer customer teams a new technology platform for use in many miscellaneous international racing and club sport series, with the Nordschleife enthusiasts not being the only interested party, as the brawny coupe also represents the perfect car for use in the Belgian Belcar series and other, non-European, endurance series."
Technical Data BMW Z4 M Coupé Motorsport Version
Length: 4415 mm
Width: 1880 mm
Wheelbase: 2493 mm
Front & Rear Overhang: 865 mm/774mm
Rear Wing Width: 1504 mm
Front & Rear Ground Clearance: 80 mm/90 mm
Front & Rear Tyres: Michelin 27/65-18, 28/71-18
Front Brake: Grey cast iron disc dia. 380 mm / 6 pot fixed calliper
Rear Brake: Grey cast iron disc dia. 320 mm / 4 pot fixed calliper
Drive Line: sequential 6-speed gearbox, sintered clutch
Engine Layout: six cylinder in line
Cylinder Capacity: 3246 cc
Bore x Stroke: 87 x 91 mm
Compression Ratio: 12,5:1
Max. Power: approx. 400 PS at 8200 rpm
Max. Torque: approx. 400 Nm at approx. 5750 rpm
Max. Revolutions per minute: 8400 rpm
Cylinder block: one-piece construction
Crankshaft: forged steel part
Piston: forged slipper skirt piston
Con-rod: Steel
Cylinder head: Aluminium, four valves per cylinder
Valve train: Two chain driven overhead camshafts with variable valve timing
Intake System: Six single throttle valves, Carbon fibre Air box with resonance induction optimised inlet pipes
Exhaust System: Multiple pipe manifold with silencer and catalytic converter
Lubricating System: Wet Sump Lubrication
Cooling System: Water / Air cooler
Flywheel: Steel
Fuel System: Inlet-Pipe Injection, one Injector per Cylinder, 5 bar injection pressure
Fuel: 5-star lead-free petrol, ROZ min=98
Fuel Tank Volume: 120 litres
Minimum Weight: 1200 kg in Nürburgring Specification
  • Svar 52
Litt lite med 400 HK til det utseendet der synes jeg.
litt lite..?
tror nok 400 hk i den bilen er mer enn nok!
spoileren bak trengs nok like mye, om man har 400hk eller 600hk..
