Hva vil dere ha? Motorer etc.
Gjest
  • Svar 128
Planer for E46 316i 1.9l 105, AR78155 "The Green Lightning"
Utvendig:
Original speil
Komplett Original M-Tech styling - Frontfanger, bakfanger, sideskjørt, spoiler på koffertlokk og haifinne
18" Replika E60 M5-felger
Teknisk:
KN/KingDragon/Green Power filter
Originalt effekt-anlegg - E46 316i 1.9l 105hk
Original M-Tech Senkesett - Dempere og fjærer (20/15mm)
AngelEyes-kit
Racing Brakes-kit
ChipTune
Innvendig:
Krom-ringer rundt intrumentpanel
///M MF ratt 3-eket 2001/2003facelift mod
///M Girkule
///M Pedaler
///M Håndbrekk
///M Innstegs-lister
Multimedia:
Focal-frontsett
Pioneer Avic X1R/X1BT
2x LCD-skjerm i nakkestøtter
Bilstereo-batteri
Oppgradert dynamo
SlimFit-PlayStation 2
2x Pioneer TS-W3004SPL subwoofer m/ bassreflex opp gjennom hattehylle og inn i kupè -Pris: 2x1990.- (Bilradiospesialisten)
Forsterker/Amplifier PIONEER PRS-D3000SPL
Competition Class SPL Class-D Amplifier
Take your in-car sound to the edge with this Class-D SPL amp. Designed to match our first-class SPL subwoofers, it puts out a razor-hot 2000 W of max. output power.
This amp is outfitted with an Independent Rail Regulating Power (IRRP) supply and a new Low Current Density (LCD) design. Highly efficient Class-D technology is part of the construction too. Less current for less heat. That means no distortion, so the sound always stays pure, crisp and clear.
Key features PRS-D3000SPL
Max. output power: 1000 W x 1 (4 Ohm) / 2000 W x 1 (2 Ohm)
Continuous output power (14.4 V): 1 x 500 W (20 - 240 kHz / 4 Ohm), 1 x 1000 W (20 - 240 kHz / 2 Ohm), 1 x 3000 W (Bridged 4 Ohm)
Load impedance capability: 4 Ohm (2 - 8 Ohm allowable)
Features PRS-D3000SPL
Type Klasse D forsterker
PWM regulated MOSFET power supply Nei
Input level/gain control Nei
Load impedance capability 2 -8 Ohm
RCA input terminals Nei
Speaker Terminals Block-type
Power / ground terminals Block-type
Crossover network Nei
LPF 40 - 240 Hz
High performance balanced isolator circuit Ja
Reversible endcaps for installation versatility Nei
MOSFET output section Nei
Time alignment Nei
Listening position Selector Nei
24-bit Burr-Brown D/A convertors Nei
Optical input Nei
High Voltage output Nei
Electronic Volume Nei
Copper-plated chassis Nei
Installation Kit Nei
Specifications PRS-D3000SPL
Maximum Output Power 1000 W x 1 (4 Ohm) / 2000 W x 1 (2 Ohm)
DIN power output (W)
(DIN45324, +B = 14.4V) 800 W x 1 (4 Ohm) / 1400 W x 1 (2 Ohm)
Frequency response 10 Hz - 240 Hz Hz
Distortion <0.05 %
S/N ratio >90 dB
Max. current consumption (A/4ohms) 42 A
Chassis size (W x H x D) 300 x 64 x 279 mm
Unit weight 5.9 kg
General PRS-D3000SPL
-Noe av dette kan vel skaffes i tyskland/utland for en billig penge?
Jeg har ingen nettside enda.. jeg har bare solgt noen deler på si liksom.. men det var voldsom respons her på bmw-forumet.. jeg har ingenting på lager ennå, tenkte bare å se hva folk ville ha - og har hørt litt rundt, og fått bekreftet at mye av det som dere har listet opp er kurant å få tak i.. har også sendt over en liste til brodern som er i tyskland nå.. så får vi se hva som skjer.. hadde vært digg visst han kom hjem med en haug av M3`er :)
thomkleven: er du på jakt etter en 525i motor? vet muligens om en som skal selge en slik..! tror det var en 92 mod som hadde gått 160k... intr?
Også kan du jo plokke med deg elektriske vinduer til E30 / E28 når du er der nede. Er visst ingen som har noe slikt... Vel og merke til en vettig pris. Man vet jo aldri hvor lenge det vil fungere når det er brukt så.. Pris max 1000 komplett med ledninger..
Gjest
