Få 5 hk ekstra i helga!?!
For de som ønsker å teste måter å få mer økning på motoren, fant jeg ett sted som selger Chip, for dette med disse påstandene:
Chipen koster mindre enn 500kr ferdig levert på posten.
Personlig har jeg ikke testet dette selv, så jeg garanterer ingen ting av det som påstås under her.
BMW 5 SERIES 1990–2010 2009 2008 2007
Improved Performance
- 50+ horsepower
- 50+ ft/lb of torque
- 50% + throttle response
- ++ smoother idling
- ++ low end acceleration
- ++ top end power
- ++ mid to high RPM revs
Improved Fuel Economy
- 10 to 12 more City MPG
- 12 to 15 more Hwy MPG
Manufactured for BMW 5 SERIES 1990–2010
Compatible with all applicable engine sizes.
2 in 1 PERFORMANCE MODULE
Redline Performance PART# RL-1556
NEW IN 2009
We are proud to introduce a new 2 in 1 fuel saving performance module to the marketplace. You no longer need to choose between performance or fuel economy when selecting a module for your vehicle. Ask any other dealer and they will tell you that installing both a performance chip and a fuel saving chip on the same vehicle simultaneously is impossible. But with our brand new 2 in 1 module you no longer need to make a compromise!
Get maximum performance and fuel saving in ONE easy to install module. After extended research and development we have developed a new updated module that will improve performance and fuel economy simultaneously at a rate that cannot be matched by our competitors. With our new and updated 2009 module we have achieved a new level of programmable technology that cannot be matched by our competitors.
**Do not be fooled by competitors claiming 70, 100, or even 200 HP. These numbers are complete fabrications! It is physically impossible to attain such extensive horsepower or fuel saving gains using this same technology. When you purchase from us you get the same performance AND fuel savings with legitimate gains for a much lower price!
Each module is developed and tested for compatibility with all available engines available for the vehicle specified.
Included in our Fuel Saving Performance Kit
1 Circuit Protected Redline 2 in 1 Performance Module
1 Complete Installation Manual - step by step, detailed instructions with diagrams
24/7 technical support -
rlineperformance@gmail.com
100% money back guarantee - if you are not completely satisfied with your purchase we will refund you the full cost of the item INCLUDING shipping costs.
Extended List of Benefits
Improved Engine Life
Reduces stress on the engine increasing the life of your engine and all related components.
Increases the life of engine oil extending the time between costly oil changes.
Reduces build up on spark plugs and engine heads.
Improved Engine Performance
50+ horsepower at the wheels! Unmatched improved engine performance!
50+ ft/lb of torque. Even more torque is possible when installed on trucks and SUVs!
Improved Engine Fuel Economy
10 to 12 more miles per gallon when driving in stop and go city traffic.
12 to 15 more miles per gallon when driving primarily on highways.
The Science of our Modules
Here is how our modules work. In 1990 the Subaru Justy came off the automobile assembly line as the last carbureted motor vehicle sold in the United States. From this point on, emissions and fuel efficiency laws forced all automobile manufacturers to manufacture and sell only fuel injected vehicles. Thankfully, fuel injection technology is reasonably simplistic and can easily be studied and improved. With performance in mind, our engineers noticed a common problem among all fuel injected vehicles. Many were running an unnecessary rich mixture of fuel and oxygen out of the factory, wasting fuel while making engines sluggish compared to their performance tuned counterparts.
Our performance modules tune your vehicle's engine to run at stoichiometric levels. Stoichiometric or theoretical combustion is the ideal combustion process during which a fuel is burned completely. Fuel is not wasted (rich mixture) and your engine isn’t starving for fuel either (lean mixture). The tuning is done through the vehicle’s on-board computer or ECU. Our module tunes your vehicle’s ECU to allow the engine to run at stoichiometric levels which maximizes performance and improves fuel economy simultaneously.
Installation and Warranty
We wanted to make our modules easy to install, allowing anyone to purchase our modules and install them on their own vehicles, WITHOUT paying a mechanic $100s of dollars for labor. That is why we take care to include detailed step by step installation instructions with each module. If you can plug your TV into a wall outlet you can plug and play our module.
Another priority for us was price point. We wanted to make our performance modules affordable. eBay allows us to sell our modules with no middleman and little overhead costs allowing us to pass the savings on to our customers.
After installing our module we guarantee you'll feel a difference in performance or your money back! Each one of our modules is backed by our UNMATCHED money back guarantee. If you are not completely satisfied with your purchase you may return your module for a full refund including the original cost of the item AND original shipping costs.
You will not find this guarantee anywhere else on eBay. We stand behind our product and we are confident that you will be completely satisfied with your purchase. Do not be fooled by competitors who emulate our auction page and try to sell you a substandard knock-off of our product.
About Us
Our company was founded in 2001 when company founder and president, Josh Matthews, was looking for a performance chip for his 1997 Ford Mustang GT. After carefully looking through the performance chip marketplace he purchased a performance chip for his GT – the cost, well over $200. After installing the chip he noticed the promised gains but just wasn’t satisfied with the price to power ratio. With a background in engineering and as a part owner of a local performance shop, Mr. Graves resolved to form his own separate business to create a performance chip that would give the same type of improved performance as higher priced options at a much more reasonable price. Redline Performance was founded two and a half years later. After several years of research and development we finalized creation of our performance modules. We have been selling performance chips locally since 2003 and we are now making our products available to the eBay community in 2009. With no middleman and little overhead costs we are able to offer our performance modules to our online customers for rock-bottom factory direct prices.
Frequently Asked Questions
Q: Do you combine shipping on multiple items?
A: Yes! We do combine shipping on multiple items. Shipping for any additional items is free! To combine your purchases simply use BuyItNow on each separate auction and then complete eBay check-out.
Q: Will your module void my vehicle's factory warranty?
A: No, installation of our module will not void your vehicle's factory warranty. A large percentage of our customers purchase modules for their new cars and trucks.
Q: Do you offer a warranty on your product?
A: Yes! Each module sold includes a LIFETIME WARRANTY along with a 100% money back guarantee. If you are unsatisfied with your purchase you may return the item for a full refund.
Q: When will my item ship?
A: Purchase before 6PM EST and your item will be shipped the same day (except for Sundays). We will notify you via e-mail as soon as your item ships.
Q: I'm looking for a module for my car, not listed in this auction.
A: Please visit our eBay store. You can use the search function or browse by vehicle make.
Q: I already have a cold air intake installed. Can your module be used in conjunction with other performance upgrades?
A: Yes, our performance modules are completely compatible with cold air intakes and other popular performance upgrades such as exhaust or headers.
Jasså, alle mellom 1990–2010.
Pluss de fra 2009, 2008 og 2007.
Det må jo være bra!
Den chiopen var vel litt optimistisk.. hehe Kunne jo vært moro å prøvd om den ga noe resultat da, siden den er såppasss billig altså...
This is not a chip of any kind, it is a resistor in a box. I purchased two of these "chips" before doing my research, boy am I sorry. I had to email the Redline guy for help on installation, he was quick to respond to that email. After I installed the "chip" using his instructions my check engine light activated. I took my van to a mechanic to find out that the chip triggered a low voltage to MAS on my intake as well as false readings to my ECM. Now the fellow won't return any emails.
So here I am $95 in the hole and nothing to show but a headache caused by this scam artist that says "5000 people can't be wrong". Well if you read the positive feedbacks you must realise that at least 1000 of the people left them before even installing the box, another 1000 left them within 12 hours of installation, and the rest were just trying to get their money back by leaving a "creative feedback" as stated by the seller on the peice of paper shipped with the "chip".
For the feedbacks that actually state that they "feel the difference", that is due to 2 reasons:
1. they are pressing on the gas harder in hopeing that the chip really works
2. the "chip" tricks the ECM/ECU into thinking it's cold thus dumping more gas into the motor. This will mess up your engine, throttle body, and injectors over time.
I hope that eBay will ban this guy for fraud, simply because a resistor is not a performance chip, it is a resistor.
Ville aldri montert en slik jalla chip i bilen min.! Den gjør garantert mer skade enn hva den forbedrer motorstyringen...
+1
<50+ horsepower at the wheels! Unmatched improved engine performance!> :roll::lol:
