BMW E36 overhaling
da har man kjøpt parkering sensorer bak til bmw :D ser ikke noe når jeg rygger om jeg treffer no så kjøpte et sånn kit da med sensorer og en sånn so piper :P bilder kommer når jeg finner den hersjens kabelen til tlf :)
  • Svar 520
  • Visninger 101.2k
Ja da har man fått tilpasse det ene understellet til bilen :D så fikk montert kjørestolen, neste er pasasjerstolen sin tur :D og har montert park sensorer i bakfangeren :D
+ fått eksosen til 328 og m3 deksel :D
og i morgen skal jeg hente på posten en obd 18 knapper ;)
Ja da fikk man 18 knappers obc :D
og her fant jeg retrofit fra analog klokke til obc :)
var noe jeg fant på nettet så får se hvordan det blir
[*]Wiring in your Full OBC, to a car with only a clock:
You will need:-
wire strippers
soldering iron
insulation tape (heat shrink tubing)
bit of wire to run into the engine bay (3m)
Temp sensor
white plug
black plug
Right, first of all, you need the black and white plugs that plug into the back of the OBC, you'll find these in any scrapped car with a full obc in it, while you're there nick the temp sensor from the engine bay too.
Basically, The white plug on the full OBC, is your power inputs etc,
The black plug on the other hand covers all the output funcions. ie, temperaure, coolant level, check control, peak speed, distance, limiter, range, mpg etc etc etc. Since the only function we are intersted in is the temperature, we will only be concerend with two wires from the black plug, where as we will need to connect four on the white plug.
WHITE PLUG:
Remove your clock and chop off the connector (not all at once though, because your metal strippers will fuse the 12V and earth wires and blow the fuse) - (cut each wires separatley and keep the plug, coz u might want to put the clock back in at a later date. By now, you'll have three wires: a permanent live (red/yellow stripes), an earth (brown) and a sidelight feed (grey/red stripes). You will also require another wire (an ignition live). To get this simply run a wire from the back of your stereo. You dont have to run one from here, just from anywhere that there is an ignition feed. In other words, a wire that only carries 12V when the ignition is switched on.
Ignore the sidelight feed for the time being and take the three wires:-
1. the perm live (red/yellow stripes)
2. the ignition live (whatever colour wire you have run from the stereo)
3. the earth (brown)
Connect these by soldering to the following wires on the white OBC plug:-
A. the (red/yellow hoops not stripes - (might be slioghtly different on early OBC's))
B. (the red/brown wire)
C. the (brown wire)
1 to A - This permanent 12V feed allows the memory in the clock to keep the correct time and date, so that each time you turn the car on, the clock still reads the correct time.
2 to B - This ignition feed, provides the power to the backlit display, this makes sure that the display only poweres up when the car's ignition is on!!
3 to C - Earth wires - self explanatory really.
BLACK PLUG:-
Run two wires into the engine bay, behind your passenger headlamp, connect these to the temp sensor, make sure that you solder and heat shrink over the joint to make it weather proof (doesnt matter which way because they are resistance wires). fit the temp senosr into the little hole in the brake ducts in the front bumper.
The other end of these wires, run into the centre console area and link to the OBC:-
Connect the afore mentioned wires to the two wires on the black plug (green/black and green/blue)
(again, it doesnt matter which way round).
Now here's where the sidelight feed comes in:-
Connect the sidelight feed (grey/red wire) to the sme colour wire on the black plug - This provides the power to the OBC buttons to light up. Since you only need these buttons to light up at night (or when it's dark) - (a sidelight feed is perfect). Because this means that when it's dark, you put your sidelights on, and when these come on, so do the lights on your OBC buttons - genious!!)
Once you have checked all six joints (3 white, 3 black), are soldered corectly and properly insulated, you have finished the hard work!!!
Plug the two plugs into the back of your OBC, tidy up the wires and then fit the computer back into place.
[*]Det med parkerings sensorene så følgte koblings skjema med at man skal bare koble det til ryggelyset V.B. der man skal montere sensorene ser man når man demonterer bakfangeren på den skumm gråe skummen som ligger oppå den krasjramma. så ser man plaseringen av sensorene. Har orginal bruksanvisningen til kobling av pdc orginalt.
Her er det kittet jeg kjøpte på ebay. http://www.ebay.com/itm/270817622163?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648
