Siste nytt fra M GmbH; M3 CRT....
Orjan
=P~ Denne er RÅ! Jeg har utrolig sans for alle slags "Lightweight" utgaver, og liker 4-dørs M3 utrolig godt, så dette er definitivt en bil for meg! I want it - BAD!!
http://www.m3post.com/forums/showthread.php?t=548729
Construction / Cosmetics
M3 "CRT" = Carbon Racing Technologies
Limited production - 67 units
Debuts new production process for CFRP (carbon fiber reinforced plastic) components
Hood and bucket seats made from cellular carbon honeycomb
Hood has strength of conventional steel hood, but at 1/4 of its weight. 50% weight saving over M3 aluminum hood.
Frozen Polar Silver metallic exterior paint
Melbourne Red metallic applications and special treatment for the BMW kidney grille
Exclusive door sill strips, door panels and trim strips in aluminium grain structure
Special Sakhir Orange and Black dual colored covers for the front and individual rear seats
Alcantara-covered M steering wheel
Powertrain / Performance
450hp @ 8,300 RPM
324lb-ft torque @ 3,750 RPM
180mph / 290kmh top speed
4,360 cc displacement
0-100km/h (0-62mph) - 4.4 seconds
Sports exhaust system with extremely lightweight titanium muffler
Bedplate crankcase construction in special aluminum-silicon alloy
Individual throttle butterflies
Knock control system with ion current technology
Dynamically-optimized wet sump oil supply
Body
3,483 pounds / 1,580 kilograms = [100lb (45kg)] lighter than standard sedan / [154lb (70kg)] lighter when equipment on board taken into account
Proportion of car's weight over rear axle raised to 48.4%
7.74 lb-per-hp weight-to-power ratio
3.5 kg-per-hp weight-to-power ratio
Wheels/Suspension
19-inch M light-alloy wheels in Y-spoke design
245/35 R 19 front tires and 265/35 R 19 rear tires
Front and rear axle enhanced by rigid rear axle subframe
Coilover suspension with individually adjustable dampers
6-piston fixed calipers with low-weight compound construction
378x32 mm front brake rotors / 380x28 mm rear rear rotors
Stahflex brake lines
Tech
Sound-proofing configured specially for low-weight construction
Two individual rear seats
M DCT w/ Drivelogic
Navigation System Professional
BMW Individual High End audio system
Alarm system with PDC sensors
