In addition to in-car DVD and CD, you can play music from any external USB memory or HDD via the handy front panel mounted port. A dual zone audio function allows front seated occupants to listen to their choice of music whilst rear-seated passenger listen to a movie on headphones.
This Multi-format player builds into a comprehensive Multimedia centre offering high-quality reproduction of Divx and Divx Ultra video as well as MP3/WMA/WAV/AAC file playback. Ready for Bluetooth, iPod and DAB via optional adaptors.
MAJOR FEATURES
» 4 X 50W MOS-FET Power Amp
» 24-Bit Resolution 1-Bit DAC
» MP3/WMA/WAV Compatible
» DVD/DVD-R/RW/VCD/CD-R/RW Compatible
» Giga MP3
» Composite Video Output Terminal
» Optical Digital Output Terminal
» Line Output Terminal (1 pair)
» Line Input Terminal (via optional KS-U58 or KS-U57J2)
» cEQ
» 2.5V Line Output Level
» 2ch Dolby Digital
» DTS DIGITAL OUT
» Detach Face
» DivX
» iPod Ready (via optional KS-PD100)
» DAB Ready (via optional KT-DB1000)
» Blutooth Ready (via optional KS-BTA200)
» DVD/CD Section
» CD Text
» Direct Track Access (1-12)
» Random/Repeat Play
» Intro Scan
» +/-10 Key Function
Changer Control Section
» MP3 Control
» CD Text
» Direct Disc Select (1-12)
» Random/Repeat Play (2 modes)
» Optional Line Input(via optional U57/U58 cable)
» +/- 10 Key Function
Tuner Section
» HS-IV Tuner
» IF Filter
» 6 AM and 18 FM Presets
» SSM (for FM)
» Seek (Up/Down)
» AFNS/PNC
» Stereo/Mono Switch (for FM)
» RDS
Amplifier Section
» Source-Specific Volume Control
» Balance/Fader Control
» Volume Attenuator
» Loudness Control
» Maximum Amp Gain Switcher
Display Section
» Union Jack LCD
» Dimmer (Manual)
» General Section
» Detachable Control Panel with Carrying Case
» Rotary Encoder Multi-Control
» Multi-Function Wireless Remote Control
» COMPU PLAY
» Power-Off Mode Eject
» Preferred Setting Mode
» Telephone Mute
» Steering Remote
» ISO CABLE
Selges for 1000+frakt
Har orginalesken, og tror jeg skal ha alt liggende. Spilleren er svært lite brukt.
Ser du bur i sogn og fjordane, kor?? Kan vere interrisert! Gadd ikkje lese alt men, er det aux og USB tilkopling, tilkopling så eg kan kople til forsterker og bass? Spiller den bra? Noke trykk i den? for hadde en kompis som skifta spiller, og berre fra det fekk han bedre lyd, og kva er nypris på denna spelaren?
Bur i førde, det e aux og usb ja, den leser også dvd, so du kan koble til skjerm også. Spilte greit med 2x12" cadence iallefall, men det må jo selvfølgelig berre prøvast med det du har. Nypris veit eg ikkje, kjøpte den hos en kompis for 1700 ifjor, og då var den helt ny, uåpna, den har kun blitt brukt i ca 4 mnd. Har fremdeles orginal emballasje.
  520dd skrev:
Bur på Vassenden, så ekje lange veien for å sei da sånn, men skal ta å tenke på det litt, om det ikkje er noken andre her som tar den, tar eg sikkert den :)
Hehe, nei då passa da bra :) Den er grei! :)
