Jims E39 520i Touring 2001, Nye zito felger S.4!
  • Svar 55
  • Visninger 6k
Hehe , neida da må jeg til å fucke med karosseriet om jeg skal ha det, å det gidder jeg ikke. Søkte om å bygge om til 530 :)
  • 3 months later...
Jim, have you installed rear view camera already? I am working on mine touring with installing camera now and it's not what i expected.. it doesn't fit without modification just because number plate lightning is different from sedan. And this camera is for sedan. So how it's going for you? :)
Hi Lydvis, same for me. i had to melt alot of the plastic to fit it. And now it wont work. So its pretty annoying.
But ill update u once spring is here cause i dont have a spot to work out other than outside.
I have already mounted in my Touring and it's working fine. Why it's not working for you? You have Dynavin, so it's more easy. I have stock navi system, so I needed special cabel to connect it via video-module and relay to get it completly working. I used all day for it, didn't expected that it will take so much time for me :)
Hi.
I finished the wiring and everything with the camera and its working just perfect now :)
It took about 10 minutes for me. The worst part was getting the video cable from the player to the back. That took 1-2 hours in total.
It looks like this now:
Fant også ut hva som var problemet med kjørelyset bak. Var ikke lykta som var gåen var ett brudd i kablene.
Slapp å ut med 2000 for ny kabel! Phew!
Nice job!! I have also finished installing camera on mine touring. Everything works fine.
It kinda looks like its not straight, but it is, im just parking outside my house where its downhill so.
Only problem is that it wont activate when i put it in reverse, i manually have to put it on the camera, which in my oppinion is useless. I gotta figure out how to do get.
And yes, i did wire the power wire on the reverse lights :P
  • 1 month later...
  • 1 month later...
