Jump to content
Recommended Posts
Posted
Hvordan tenningsmap er det på dette? OG bensin? er det 8x8? 16x16?
Plug n Play
Full Fuel and Timing Control, Full Standalone, Fully Adjustable
Factory Sensors OK
Factory Sensors can be retained, however if they need to be changed, (like upgrading to a bigger map sensor), AEM has a full line of sensors available and we stock them!
Basemap Included
Password Protection
Direct Fire Ignition (no resistor box required)
16 General Outputs
8 General Inputs
Use these inputs to log various additional sensor readings (Wideband, Air Temp, Fluid Pressure, etc). These inputs can also be used to trigger fail-safes for boost, meth/water/alcohol injection, and much more
4 EGT Inputs (for fuel control)
Internal Logging Memory
Log data straight to the computer and review the session with your laptop all from within the computer.
FULL IDLE CONTROL
Customizable Traction Control
Full Boost Control (with optional boost control solenoid)
3-Step Launch Control
Nitrous Control
Definable Knock Control
USB Compatible
and more...
  • 2 months later...
Create an account
Register a new account
Sign in
Sign In Now
  • Recently Browsing   0 members
    • No registered users viewing this page.
  • Create New...
