Hva skjer med en BMW M5 E60/61 når man trykker på M knappen?
Tenker på:
- understellet -> stivere understell, men hva med høyden. Er den lik / forrandrer seg ikke? Dvs at den ike senker seg eller noe slik?
- giren -> raskere giring, og det kan jo stilles på...
- motor -> mer power, men mer turtall? Og raskere respons.
- aktive seter -> blir stivere?
Alt dette skjer samtidig?
Haha, den hadde jeg godt av :-)
Takker, har brukt den selv lmgtfy (let me google it for you) :-)
Fant noen svar på spørsmålene
The button can be configured for several settings such as gear change speed.
As far as I know the following happens:-
remap to give extra 107bhp using electronics only increased throttle response
DSC is altered to give more driver control
suspension is stiffened for handling
gearbox change speed is increased to setting
and the engine noise is fantastic at 7000rpm
Og
Specifically, the following functions are selected with MDrive
or enabled:
- The power button, with the engine characteristics - ie power
and response - is affected in three stages;
- SMG Drive logic within which one of the six sequential
five or automated switching programs will be selected -
Here too, the driver benefits from the direct selection of words in each
desired driving or switching program;
- The DSC stability control with its two driving dynamics programs;
- EDC Electronic Damper Control with three programs
Comfort, Normal and Sport;
- The head-up display HUD and
- The active backrest width adjustment ALBV.
Og
About the power button on the selector lever cover, the driver can
Enable sportier program at the full performance characteristics.
Here, with respect to an accelerator pedal to throttle opening
using progressive characteristic curve and the dynamic transfer functions
the electronic engine control spontaneous response
switched. The more comfortable of the two programs in the M5
called automatically when the engine is restarted. the
Program changeover can also preconfigured in the MDrive and
be retrieved. Only in MDrive is another, very sporty
Obtains program.
MEN sier ikke noe om høyden på understellet senker seg, når man trykker på knappen, så den gjør kanskje ikke det. Blir bare stivere / mer response.
Dette må være det beste svaret viss du vil ha det kjappt og enkelt!
Se gjerne del 1 viss du vil høre en haug me vas fra Jeremy :lol:
Trykker på knappen på 1:00 forresten!
