Er d noen som har erfaring med å endre lands kode i dashboard? Min er låst til D, det påvirker og har sammenheng med lcm og navigasjon + radio. Etter oppgradering av software, har det dukket opp en del tull som det nå viser seg å ha sammenheng med nettopp landskoden.
Skrevet (endret)
Her er litt om saken. På engelsk. Samt en link i bunn. Du finner mye om emnet ved å google "BMW e39 OBD codes".
Turn ignition to pos. II
Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22
Push the right button until you see "Test Nr.19"
Push left button until you see the number that is equal to the one you calculated above
Push right button again
Now you will have unrestricted access to Test No.3-21. If you made an error in the procedure mentioned above, Test No.3-21 will only display Lock:ON
Most of the tests are self-explaintory, and here is a first listing (as far as I can recall):
1. Display Car's identification number, HW/SW version, date of construction
2. A very beautiful instrument test
2. Current consumption (liters/100 km)
3. Current consumption (liters/hour)
4. Average consumption (liters/100 km)
5.Current range
6. N/A
7. Average fuel in tank (liters)
8. Current Speed (kph)
9. System voltage at Term. "R" (Battery Voltage)
10.Country/Language (US, Spa, Ger, Jap, etc.)
11. Units am/pm
12. Average Speed
13. ETA
14. Date of Software Mask
15. Production Diagnosis
16. ""
17. Display Vehicle Specific Data
18. Alarm Changeover (cont. vs. intermittent OBC chime)
19. Lock/Unlock
20. Correction factor for fuel consumption (nicht ändern!)
21. Reset all defect codes
http://www.ideaphile.com/bmw/540-obc.html
Redigert...
En til..
Endret av MrBrum
Har prøvd dette men får ikke annen mulighet/valg enn tysk. Har nå prøvd BMW scanner , heller ikke her er d noen valgmulighet, ser at jeg kan programmere noen eeprom, men må viite hvilken av de og hva skal skrives.....
