Noen som kan hjelpe? Transmission failsafe mode.
thommas88
Opplever at bilen viser transmission failsafe mode. hatt bilen i 5 uker nå og fått den meldinga 3-4 ganger.
Det er en 525A og det skjer bare når jeg har den i manuell modus. Sist så kom den når jeg skulle bremse på gira. Satte den i manuell før bakken starten og så klarer den ikke å holde giret eller detter ut av giret.
E R R O R   M E M O R Y           ---------------------------------------
Date:      29.10.2015 15:30:06 ECU:       GS19A JobStatus: OKAY Variant:   GS19A-------------------------------------------------------------
RESULT:    1 error in error memory !-------------------------------------------------------------
4F8F  Ratiocontrol control 3-2
P17EE Ratio Monitoring Shift 3-2
Error counter:    1 Logistic counter: 39
   Mileage                                 151624     km   actual engine torque                         8.00  Nm   Gearbox Oil Temperature                     82.00  degrees C   Output Speed                              1408.00  rpm   Turbine speed (rpm)                       1376.00  rpm
   Plausibility   Test conditions not yet fulfilled   Error not present now, but already stored   Error would not cause a warning lamp to light up
Error code: 4F 8F 38 17 EE 00 00 01 27 4A 09 1B 7A 2C 2B 00            00 00 00 00 00 00 00 00 00 00 00 =============================================================
I N F O R M A T I O N   M E M O R Y           ---------------------------------------
Date:      29.10.2015 15:31:29 ECU:       GS19A JobStatus: OKAY Variant:   GS19A-------------------------------------------------------------
4F86  Ratio-Monitoring Symptom Circuit-Monitoring
Error counter:    29
1. Umweltsatz   Mileage                                 143808     km   condition WK         torque converter-clutch open  0-n   Type of Shift             Type of Shift 1 after 2  0-n   actual engine torque                         4.00  Nm   Gearbox Oil Temperature                     61.00  degrees C   Output Speed                                64.00  rpm
2. Umweltsatz   Mileage                                 143808     km   condition WK         torque converter-clutch open  0-n   Type of Shift             Type of Shift 3 after 2  0-n   actual engine torque                         4.00  Nm   Gearbox Oil Temperature                     82.00  degrees C   Output Speed                               736.00  rpm
3. Umweltsatz   Mileage                                 151624     km   condition WK         torque converter-clutch open  0-n   Type of Shift             Type of Shift 3 after 2  0-n   actual engine torque                         8.00  Nm   Gearbox Oil Temperature                     82.00  degrees C   Output Speed                              1408.00  rpm
   Symptom Circuit-Monitoring   Test conditions not yet fulfilled   Error present now and already stored   Error would not cause a warning lamp to light up
Error code: 4F 86 78 1D 46 38 08 1A 65 02 46 38 10 1A 7A 17            4A 09 10 1B 7A 2C =============================================================
Mulig det trengs å bytte noe som på engelsk heter solenoids. Ikke sikker på hva det heter på norsk. Har du flaks kanskje det holder å flushe kassa.
Mulig snikende feil på motor sensorer også kan gi dette symptomet. F. eks en dårlig kam sensor som enda ikke har gitt feil kode.
Men her trengs diagnose utstyr sammen med fag kunnskap for å avdekke slike syndere. (hvis man vil finne feilen fremfor å "bytte og se")
