Bmw.e34 Skrevet April 12, 2020 Skrevet April 12, 2020 va å feilsøkte på bilen min (e34 525tds, m51d25), opg fikk opp noen feilkoder på tysk. Prøvde å oversette sjøl men kom aldri fram til noke fornuftig. Noken tyske her som kunna oversatt alt so det er mulig å skjønne? teksten står på bilde !
Flataas Skrevet April 12, 2020 Skrevet April 12, 2020 (endret) Om du hadde tatt et skjermbilde inne på datamaskinen så hadde det vært lettere å tyde. Legger ved feilkode liste til DDE 2 DDE 2 and DDE 2.1 1 Injection Pump Mass Positioner 3 Shut off Valve 5 Injection Start Sensor Cyl4 6 Glow Plug Timing Control 8 Exhaust Gas Recirculation 10 Injection Phasing Control Deviation 15 Voltage Supply DDE 20 Cruise Control Switch 21 Injection Pump Position Potentiometer 28 Clutch switch 29 Vehicle Speed Signal 31 Brake Switch 35 Fuel Temperature Sensor 36 Fuel Filter Water Trap 37 Pedal Position Sensor 41 Glow Plug Timing Control 45 DWA Immobiliser 47 RPM Sensor 52 Charge Air Temperature Sensor 53 Coolant Temperature Sensor 54 Boost Pressure Sensor 56 DDE Internal Fault 58 DDE Output Stage Error 59 Boost Pressure Deviation DDE 2.2 01 Delivery Controller Deviation 03 Shut off Valve 04 Glow Plug Indicator Lamp) 05 Needle Motion Sensor 06 Exhaust Gas Recirculation Deviation 07 Exhaust Gas Recirculation 08 Glow Plug Timing Control 09 DDE Error 10 Injection Phasing Control Deviation 11 DDE Error 15 DDE Power Supply -Main Relay 16 Voltage Supply B+ 20 Cruise Control Operation 21 DDE Error 23 AirCon Signal 25 Pedal Position Sensor 26 Brake Light Switch or Brake Light Test Switch 28 Auto Gearbox Selector Switch 29 Vehicle Speed Signal 30 EGR Switch 31 Brake Light Test Switch 32 Multifunction Steering Wheel Cruise Control 35 Fuel Temperature Sensor 36 Oil Temperature Sensor 37 Pedal Position Sensor 38 Air Flow Meter HFM 42 ADS 44 AirCon Switch 45 DWA Signal 46 DDE Error 47 RPM Sensor 49 Signal to Instrument Cluster 52 Intake Air Temperature Sensor 53 Coolant Temperature Sensor 54 Boost Pressure Sensor 56 Injection Pump Position Sensor 58 Injection Quantity 59 Boost Pressure Control 60 DDE Power Supply 63 Cruise Control Adjustment 64 DDE Error 66 Fuel Supply 67 Air Supply Deviation 100 Cruise Control Adjustment Fault 101 Boost Pressure Control Deviation 102 DDE Error 103 DDE Error 104 DDE Error 105 DDE Error 106 DDE Output Stage 108 Variant Coding 109 Variant Coding 110 AirCon Poor Operation 111 EEPROM checksum Injection Pump Adaptation 112 CAN Error – EGS Control Unit 113 CAN Error – ASC Control Unit 114 CAN Error – Instrument Cluster Endret April 12, 2020 av Flataas
