kilronan
Alt skrevet av kilronan
  1. Denne er kanskje litt lettere å forstå: Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/4 second and release it 5. With no delay press Trip Reset several times to select one of the following function s BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test
  2. Ja, velg sort i frontlyktene. Og røde/klare baklykter. Dvs. så lenge du klarer å holde deg unna lexus-helvete så kan du egentlig velge hva som helst
  3. kilronan
    318 e90
    318i og 318d + stasjonsvogn kommer i september. I følge bilnorge.no vil prisen på 318 sedan ligge rundt 330.000,-
  4. Elgen er skogens konge, bare fordi BMW har jo ikke noe i skogen å gjøre.. Om du ikke kjører X3 / X5 da.. Men det er jo en annen sak. Ja, for dette er jo biler som har utmerket seg med eventyrlige egenskaper i terrenget. Spesielt X3.
  5. Ikke vær trygg på at du er like heldig neste gang. Og skal du kunne konstatere at BMW er best på elg-treff så må du først prøve å kjøre ned noen flere elger med andre biler. Uansett glad det gikk bra
  6. Ja, det du skrev der er faktisk veldig viktig. Såpe-svampene inneholder gjerne mer enn bare såpe. Bruk heller en ren svamp og en spesialshampoo for bilvask. Avslutt deretter med polering.
  7. Hva var dine konkrete arbeidsoppgaver som assisterende økonomisjef i staten? Og hvorfor sluttet du? Høres ut som en artig jobb.
  8. Jeg vet ingenting om deg men jeg registrerer at du er 20 år. Har du utdannelse innen økonomi eller ble du lært opp når du begynte? Du sier også at du lurer på hvor alle pengene blir av. Det burde du vite som ass. økonomisjef i staten.
  9. Digger deg ass Hater den gestapo regjeringen som sitter nå. Carl I. Hagen er den eneste med litt vett i hodet. som faktisk klarer og svare ja eller nei i en debatt. istedenfor. hmm assa det kommer an på ditt og datt. Tenk på hvor mange ganger staten melker deg for penger i løpet av en lønning. Er 20 år og betaler 36% skatt. Så kjøper jeg bensin og da går 80% av det til staten. kjøper jeg meg pils i helgen og må betale ca 60% der også. og røyk etc. Spørr du meg burde de ha nok penger til å kle trafikk lysene i diamanter. HVOR FAEN ER ALLE PENGENE Joda, mye vil ha mer og hvem som helst kan jo klare å kritisere staten for alt som er galt. Først og fremst er det ikke alt innen økonomistyring på nasjonalt nivå som er åpenbart og logisk. De som tror at oljepengene fungerer som en konto vi bare kan ta ut penger fra når vi trenger noe nytt, tar feil. Oljepengene er faktisk ikke bare 'våre' penger. De tilhører også fremtidige generasjoner. Men dette nevnte jeg jo i en post lenger opp. Når man er 20 år og har dårlig råd så skulle en selvfølgelig ønske at man slapp å betale skatt, at bensinen kostet tre kroner og at penger til firefelts motorveier kunne tas rett fra pengesekken. Men i virkeligheten så er det selvfølgelig mye mer komplisert enn som så. Nøyaktig hvor komplisert det er kan man få et innblikk i ved å f.eks snike seg inn på en forelesning i makroøkonomi ved nærmeste høgskole.
  10. Jeg er jo enig at 19" på E46 er penest. Men han hadde jo satt opp 17 eller 18. Så av dem blir det selvsagt 18. Skulle ønske jeg selv hadde 17" på vinter. 15 er jo såååå dritkjipt. Jeg ser på det slik; om vinteren ser bilen ut som et helvete uansett. Og breie vinterhjul er jo derfor litt meningsløst. Poenget med å skifte til vinterhjul er jo at man skal få radikalt bedre kjøreegenskaper på vinterføre enn med sommerhjulene. Breie vinterhjul er i hvertfall ikke gunstig på snø og slaps selv om de visstnok skal være bedre på is. Men det er jo en helt annen diskusjon
  11. ..og det er i hvertfall kjipt for de som kjører Lexus. De ser ut som rånere med en gang de har henta bilen i butikken.
  12. Skal man først investere i store hjul så ser heller ikke jeg vitsen med 17". Joda, det er et godt kompromiss mellom komfort og sportslighet, men det er forsåvidt 16" også. Gå for 18" Jeg har 225/40-18 AVS-Sport foran og bak på min. Funker veldig bra.
  13. Norge er heldigvis et av de minst sinnsyke landene i hele verden. Men ingen er perfekt
  14. Poenget mitt er at verden ikke er så enkel at man helt uten videre kan sammenligne 4 kroner i USA med 11 kroner i Norge. Når det gjelder bil så er USA selvfølgelig i en helt spesiell situasjon. Her prater vi om et land som i motsetning til Norge har et ganske spesielt kjærlighetsforhold til bilen. I følge statistikk er gjennomsnittslønnen i USA ca 240.000 NKR (tall fra US Dep. of Labor) mens tilsvarende snitt i Norge ligger på ca 336.000 NKR (tall fra ssb.no). Men det er jo hyggelig at dine familiemedlemmer klarer seg bra For turister som kommer til Norge så vil det være dyrt, men for oss selv med vårt lønnsnivå er det ikke nødvendigvis det. Økonomi er komplisert. Men det er faktisk ofte en grunn til at ting er slik de er. Oljefondet er f.eks ikke bare en vanlig lønnskonto som vi kan ta ut penger fra når vi har lyst på noe nytt. Men å forklare hvorfor det er slik til mannen i gata er ikke lett. Man kan godt si at finansministeren her har et pedagogisk problem av dimensjoner. Jeg vil ikke forsvare hvorfor ting er slik de er, men faktum er at svært få har ork til å studere hvordan ting henger sammen. Og da er det jo klart man rister på hodet når man f.eks ser hvor mye bilen koster i USA.
  15. Joda, bensin er billig i USA men.. Dette er mer et skoleeksempel på hvordan man lager en tabloid artikkel som skal få den norske mannen i gata til å riste enda mer på hodet. Det har jo nærmest gått sport i å klage over bensinpriser i Norge. Men å sammenligne 4 kroner i USA med 11 kroner i Norge blir jo selvfølgelig ikke riktig. Skal man gjøre en rettferdig sammenligning må man f.eks se på hvor mye en amerikaner må jobbe for en full tank i forhold til det en nordmann må jobbe for en full tank bensin. En amerikaner kan jo ikke bare kjøpe luksusbiler i hytt og gevær fordi de bare koster halvparten av det de koster i Norge.
  16. Enig.
  17. Fin bil ja Er baklyktene originale?
  18. MacSi: Du har koblet dine ringer til parklysene?
  19. Det finnes en del måter å koble dem, men den vanligste er å koble den på en ledning i ECU'en - den hvite boksen til høyre i motorrommet med masse elektronikk i. Kobler du på riktig ledning så vil ringene lyse så lenge du har tenningen på. Parkeringslysene vil dermed ikke bli berørt. Det vil si at ringene er dekket til på baksiden slik at lys ikke reflekteres bakover og inn i reflektorene. Det vil si at ringene lyser opp når du låser opp bilen. Når bilen ikke er låst så kan du f.eks slå på ringene ved å trykke på "lås opp"-knappen på nøkkelen. Når du låser bilen så fader lyset i ringene ut (sammen med interiørbelysningen). Slik er det i hvertfall hos meg.
  20. Hm? Ringene passer til alle e46 sedan/touring (inkludert facelift). De passer også alle e46 coupe uten facelift. Det finnes egne sett til facelift-coupe, men disse er litt mer komplisert å installere. Hint: JleviSW selger nå Predator Chromium til $124.99. Det blir vel ca 12-13hundre norske inkludert frakt og allting. Dette tilbudet varer ikke evig.
  21. Takk Ikke så langt unna; Sørlandshallen.
  22. Hah, knallfett Hva heter disse da? Og velkommen i klubben
  23. Jeg ville heller gått til byen..
  24. Prøv finalgear dått com
