02 Touring
819 -
Alt skrevet av 02 Touring
Den kommer 15mm lenger ut.
På en opel?
Disse kan brukes på m50 med vanos og M52 Test " Online ETK" Part Cross-reference Part 11121703637 (CYLINDER HEAD WITH BEARING LEDGES) was found on the following vehicles: E34: Details on E34 E34 525i TOURING, U.S. E34 525i SEDAN, U.S. E34 525i SEDAN, Euro E34 525i TOURING, Euro E34 525ix TOURING, Euro E34 525ix SEDAN, Euro E36: Details on E36 E36 323i CONVERTIBLE, U.S. E36 323i COUPE, U.S. E36 328i SEDAN, U.S. E36 328i COUPE, U.S. E36 328i CONVERTIBLE, U.S. E36 M3 CONVERTIBLE, U.S. E36 M3 SEDAN, U.S. E36 M3 COUPE, U.S. E36 323i TOURING, Euro E36 323i SEDAN, Euro E36 323i COUPE, Euro E36 323i CONVERTIBLE, Euro E36 323ti COMPACT, Euro E36 328i SEDAN, Euro E36 328i COUPE, Euro E36 328i CONVERTIBLE, Euro E36 328i TOURING, Euro E38: Details on E38 E38 728i SEDAN, Euro E38 728iL SEDAN, Euro E39: Details on E39 E39 528i SEDAN, U.S. E39 523i TOURING, Euro E39 523i SEDAN, Euro E39 528i TOURING, Euro E39 528i SEDAN, Euro Z3: Details on Z3 Z3 Z3 2.8 ROADSTER, U.S. Z3 Z3 M ROADSTER, U.S. Z3 Z3 M COUPE, U.S. Z3 Z3 2.8 ROADSTER, Euro Z3 Z3 2.8 COUPE, Euro Details for all Search another part: Enter 11-digit or 7-digit Part Number: U.S. Euro Home
http://www.bimmers.no/statisk.php?id=hjulspecs
Har du ikke GARANTI?
Part Cross-reference Part 34116761237 (REPAIR KIT, BRAKE PADS ASBESTOS-FREE) was found on the following vehicles: E36: Details on E36 E36 318i SEDAN, U.S. E36 318ti COMPACT, U.S. E36 316g COMPACT, Euro E36 316i COUPE, Euro E36 316i TOURING, Euro E36 316i SEDAN, Euro E36 316i 1.6 COMPACT, Euro E36 316i 1.9 COMPACT, Euro E36 318i CONVERTIBLE, Euro E36 318i TOURING, Euro E36 318i SEDAN, Euro E36 318is SEDAN, Euro E36 318tds COMPACT, Euro E36 318ti COMPACT, Euro Z3: Details on Z3 Z3 Z3 1.9 ROADSTER, U.S. Z3 Z3 1.8 ROADSTER, Euro Z3 Z3 1.9 ROADSTER, Euro Details for all Search another part: Enter 11-digit or 7-digit Part Number: U.S. Euro Home
http://www.carbibles.com/tyre_bible_pg2.html
Ta kontakt med forsikringselskapet ditt med opplysning om bytte av spidometer og gammel og ny km. Da har du dokumentasjon.
Det ser ut som det er 2 beholdere Clutch http://www.realoem.com/bmw/showparts.do ... g=21&fg=10 Brems http://www.realoem.com/bmw/showparts.do ... g=34&fg=25
http://www.autopower.se PÅ VENSTRE SIDE Gjør det selv.
Sorry feil bil. De er like Part Cross-reference Part 33311128670 (RUBBER MOUNTING) was found on the following vehicles: E32: Details on E32 E32 735i SEDAN, U.S. E32 735iL SEDAN, U.S. E32 740i SEDAN, U.S. E32 740iL SEDAN, U.S. E32 750iL SEDAN, U.S. E32 730i SEDAN, Euro E32 730iL SEDAN, Euro E32 735i SEDAN, Euro E32 735iL SEDAN, Euro E32 740i SEDAN, Euro E32 740iL SEDAN, Euro E32 750i SEDAN, Euro E32 750iL SEDAN, Euro E32 750iLS SEDAN, Euro E34: Details on E34 E34 525i SEDAN, U.S. E34 525i TOURING, U.S. E34 530i TOURING, U.S. E34 530i SEDAN, U.S. E34 535i SEDAN, U.S. E34 540i SEDAN, U.S. E34 M5 3.6 SEDAN, U.S. E34 524td SEDAN, Euro E34 525i TOURING, Euro E34 525i SEDAN, Euro E34 525ix TOURING, Euro E34 525ix SEDAN, Euro E34 530i SEDAN, Euro E34 530i TOURING, Euro E34 535i SEDAN, Euro E34 540i SEDAN, Euro E34 540i TOURING, Euro E34 M5 TOURING, Euro E34 M5 3.6 SEDAN, Euro E34 M5 3.8 SEDAN, Euro E34 518g TOURING, Euro E34 518i TOURING, Euro E34 520i SEDAN, Euro E34 520i TOURING, Euro E34 525td TOURING, Euro E34 525td SEDAN, Euro E34 525tds TOURING, Euro E34 525tds SEDAN, Euro E34 518i SEDAN, Euro Details for all Search another part: Enter 11-digit or 7-digit Part Number: U.S. Euro Home
E34 525IX har 16x7,5 et54
Dette er stjålet fra en tidligere tråd. Dette trenger du (og litt til) Svinghjul, komplett clutch, mastersylinder, slavesylinder, ny tank til bremseveske,slanger og rør, pedalsett, gearkassetravers, gearspak med overføringer. lager i veivaksel, Det er sikkert mere som er glemt.. Koble hjernen i P eller N.
§ 1-4. Hjul 1. For motorvogn som har hjul og er konstruert for fart over 30 km/t, gjelder følgende: a) Dekk på bil, motorsykkel, traktor, motorredskap, tilhenger eller tilhengerredskap skal ha mønsterdybde minst 1,6 mm. Dekk på kjøretøy som nevnt i første ledd skal likevel ha mønsterdybde minst 3 mm i tiden fra og med 1. november til og med mandag etter 2. påskedag. I Nordland, Troms og Finnmark er tilsvarende periode fra og med 16. oktober til og med 30. april. Hjul på samme aksel skal ha dekk med tilnærmet samme egenskaper. c) Hjulene må være i tilstrekkelig statisk og dynamisk balanse. 2. Kjøretøy må ikke brukes uten at det er sikret tilstrekkelig veggrep i forhold til føret, om nødvendig ved bruk av vinterdekk med eller uten pigger, kjetting eller liknende. Vinterdekk er spesielt merkede dekk, særskilt fremstilt for vinterkjøring og med mønsterdybde minst 3 mm. Bare vinterdekk tillates brukt med pigger, med unntak av dekk til motorsykkel. I kjøretøy med tillatt totalvekt over 3 500 kg skal det, hvis det kan ventes kjøring på offentlig veg som er snø- eller isdekket, og i alle fall i tiden fra og med 1. november til og med første mandag etter 2. påskedag, medføres kjetting som er tilpasset kjøretøyets hjul og som er slik at det alltid er kontakt mellom kjetting og vegbane. Kjettingen skal være laget av metall/stål, være egnet for føreforholdet og tåle den påkjenning den blir utsatt for ved kjøring på vinterføre. I Nordland, Troms og Finnmark er tilsvarende periode fra og med 16. oktober til og med 30. april. Antall kjettinger som skal medføres etter annet ledd: a) I motorvogn med tillatt totalvekt over 3.500 kg skal det medføres minst tre kjettinger, hvorav en er tilpasset motorvognens forhjul og to er tilpasset drivhjul. I vogntog bestående av motorvogn og tilhenger hvor begge kjøretøyene har tillatt totalvekt over 3.500 kg, skal det medføres minst sju kjettinger dersom motorvognen har tvillinghjul på drivakselen. En kjetting skal være tilpasset motorvognens forhjul, fire kjettinger skal være tilpasset motorvognens drivhjul og to skal være tilpasset tilhengerens hjul. Dersom motorvognen har enkle hjul på drivaksel eller det nyttes dobbeltkjetting, er fem kjettinger tilstrekkelig, hvorav to er tilpasset motorvognens drivaksel. c) I motorvogn som er utstyrt med automatisk opererte kjettingslynger for drivhjulene (« on spot ») erstatter dette to kjettinger i de tilfellene motorvognen har tvillinghjul på drivakselen. 3. Piggdekk eller kjetting må ikke brukes i tiden fra og med første mandag etter 2. påskedag til og med 31. oktober om ikke føreforholdene gjør det nødvendig. I Nordland, Troms og Finnmark er tilsvarende periode fra og med 1. mai til og med 15. oktober. Vegdirektoratet kan gjøre unntak fra dette forbudet. 4. a) Dersom bil med tillatt totalvekt ikke over 3 500 kg, tilhenger/tilhengerredskap som er konstruert for fart over 50 km/t og som har driftsbrems eller motorsykkel utstyres med piggdekk, skal kjøretøyet ha piggdekk på alle hjul. Bil som nevnt i foregående ledd kan likevel ha piggdekk på en aksel og kjetting ellers. Dersom bil med tillatt totalvekt over 3.500 kg utstyres med piggdekk, skal den ha piggdekk på hjul som sitter på samme aksel. Det samme gjelder traktor/motorredskap som er konstruert for fart over 50 km/t. c) Det er tilstrekkelig at bare ett hjul i tvillingmontering har piggdekk så framt piggdekkene plasseres symmetrisk om kjøretøyets lengdeakse. d) På kjøretøyet skal det være tilnærmet like mange pigger i alle piggdekk. e) Reservehjul må bare brukes når det oppfyller de krav som gjelder kjøretøyets øvrige hjul. Ved tilfeldig skade på et dekk kan det likevel kortvarig brukes piggdekk på sommerføre eller sommerdekk på vinterføre. I slikt tilfelle kan ulike dekktyper blandes. På personbil er plass-sparende eller lett reservehjul tillatt. Dekket eller felgen må være merket med høyeste fart. Bruken må være beskrevet i anvisning som følger hjulet eller er tatt inn i bilens instruksjonsbok. Hjulet må bare nyttes under nødvendig transport til nærmeste reparasjonssted.
de ble levert med 17" http://www.realoem.com/bmw/showparts.do ... g=36&fg=15 Det er rart ikke flere bruker Onlin ETK
De står hva delen fra 316 compact passer på. Ergo så passer de ikke på IS eller andre. Jeg trodde det gikk klart frem av lista.
316 compakt passer på: Part 34111164221 (BRAKE CARRIER) was found on the following vehicles: E36: Details on E36 E36 318ti COMPACT, U.S. E36 316i SEDAN, Euro E36 318i SEDAN, Euro E36 318tds SEDAN, Euro E36 316i 1.6 COMPACT, Euro E36 316g COMPACT, Euro E36 316i COUPE, Euro E36 316i TOURING, Euro E36 316i 1.9 COMPACT, Euro E36 318i CONVERTIBLE, Euro E36 318i TOURING, Euro E36 318tds TOURING, Euro E36 318tds COMPACT, Euro E36 318ti COMPACT, Euro Z3: Details on Z3 Z3 Z3 1.9 ROADSTER, U.S. Z3 Z3 1.8 ROADSTER, Euro Z3 Z3 1.9 ROADSTER, Euro Details for all Search another part: Enter 11-digit or 7-digit Part Number: U.S. Euro Home Copyright © realoem.com.
Uten Vanos http://www.realoem.com/bmw/showparts.do ... g=11&fg=18
Når plinget kommer, og gradetallet blinker. Da er det årsaken til plingen.
Det er rett. http://www.vegvesen.no/cs/Satellite?c=P ... InnholdMal
Bilen gikk varm i går, hva kan det være (Feilsøking)
emne svarte i 02 Touring sin Haug530D i Teknisk
Om du tror termostaten er defekt! Da tar du den ut og kjører uten. Koker den fortsatt, er det pumpe eller tett radiator (frosset) -
Det er vel 14mm bolter på X3 og 12mm på 525ix Tror det må lages foringer i bolthullene da. Jeg har felger fra E36 med bredde 7.5" og ET 42 på min.
På vår Compakt var det løpehjulet ved siden av dynamoen som var synderen til tikking. Ta en lang stang/skrutrekker/stetoskop og lytt på senteret av løpehjulet.
