Dette fant jeg på den linken. Er det den rette kassen eller
Hydra-Matic 5L50-E Transmission (M22/MV3) What's New or Changed View Photo Top of Page
Type: five speed rear-wheel-drive, electronically controlled, automatic overdrive transaxle with torque converter clutch, driver shift control
Engine range: 4.6L
Maximum engine torque: 311 lb-ft (420 Nm)
Maximum gearbox torque: 494 lb-ft (670 Nm)
Gear ratios:
First: 3.42
Second: 2.21
Third: 1.60
Fourth: 1.00
Fifth: 0.75
Reverse: 3.02
Maximum shift speed: 1-2 6500 rpm
2-3 6500 rpm
3-4 6500 rpm
4-5 6500 rpm
Maximum validated gross vehicle weight: 7716 lb (3500 kg)
5-position quadrant: P, R, N, D & DSC +/-
7-position quadrant: P, R, N, D, 4, 3, 2
Case material: die cast aluminum
Shift pattern: (3) two-way on/off solenoids
Shift quality: variable bleed solenoid
Torque converter clutch: pulse width modulated solenoid control
Converter size: 258 mm dual plate (reference) (diameter of torque converter turbine)
Fluid type: DEXRON III
Transmission weight: wet: 86 kg (190 lb)
Fluid capacity (approximate): dry: 9 L (9.5 qt)
Pressure taps available: line pressure
Transfer design: two-axis design
Assembly sites: Strasbourg, France
Applications: Cadillac XLR (M22)
Cadillac SRX (MV3/M22)
Da tåler kassen opp til 420 nm i motoren og 670 nm i kassen eller er det feil.
Tusen takk for bra svar
