Larsgunnar's '87 E30 325i | Ferdiglakkert karosseri, S.59
Fikk ikke tak i noe skikkelig koblingsskjema, stod bare K1, K2, K3 osv, men stod ikke K1 osv på reléene. Fikk en kompis til å se på det, han plasserte bare reléene i boksen å sa at alle var like, så tror nok ikke det er helt på G der enda...
Har du noe forenklet skjema på det? Isåfall hadde det vært kanon!
Kan dette hjelpe?
Fuse - Rating - Description
1 - 7.5 - Headlight, left high beam
2 - 7.5 - Headlight, right high beam
3 - 15 - Aux. cooling fan, low speed
4 - 15 - Turn signals, Emergency flasher, Active check control, Digital clock
5 - 30 - Windshield wiper and washer
6 - 7.5 - Stop lights, Cruise control, Active check control, ABS, Interior lights
7 - 15 - Horn
8 - 30 - Rear defogger
9 - 15 - Fuel delivery, Idle speed
10 - 7.5 - Seat belt warning system, Service interval indicator, Tachometer/fuel economy gauge, Instrument gauges and indicators, Brake warning system, Back-up lights, OBC, Starter, Fuel delivery, Idle speed, Active check control, Stop lights and cruise control
11 - 7.5 - Fuel pump
12 - 7.5 - Radio power, Speedometer/instrument indicators, OBC, Multifunction Clock
13 - 7.5 - Left Low Beam
14 - 7.5 - Right Low Beam
15 - Not Used
16 - 15 - Heated Seats
17 - 30 - Sunroof, Power Windows
18 - 30 - Aux. cooling fan, high speed
19 - 7.5 - Aux. cooling fan, Interior lights, Power mirrors
20 - 30 - Heater/Air conditioner, Auxiliary Radiator cooling fan
21 - 7.5 - Glovebox light, Flashlight, Ignition Key/Seat Belt warning, Interior Lights, Radio Memory, Trunk Light, Active Check Control, Service Interval Indicator, OBC, Fuel delivery, Tachometer/Fuel Economy Gauge, Digital Clock, Multi Function Clock
22 - 7.5 - Active Check Control, Front Parking Lights, Taillights, Front Side Marker Lights
23 - 7.5 - Instrument Panel Lights, Front Parking Lights, Tail-lights, Rear Side Marker/License Plate Lights, Active Check Control, Rear Defogger, Multi-Function Clock, OBC
24 - 15 - Turn Signals, Emergency Flasher
25 - Not Used
26 - Not Used
27 - 30 - Interior Lights
Central Locking
OBC
Radio Amplifier
28 - 30 - Lighter,Power Antenna
29 - 7.5 - Left Fog Light
30 - 7.5 - Right Fog Light
  • Svar 918
  • Visninger 93.4k
  • Startsperren til Defa er enkel å kople bort. Den ledningen FRA tenningslås (som jeg kaller klemme 50, remember?) skal gå direkte ned til startmotor. Den som har koplet til Defa startsperre har klippet
Ikke enda nei, Roger! :)
Pedi:
Alle sikringene har jeg fått på rett plass, men det er det reléene jeg plages med.
Jeg vet ikke hva NOEN av reléene er til, og heller ikke hvor dem skal stå. Hadde det bare stått K1, K2 og K3 osv på reléene så hadde det jo vært såre enkelt.
Om noen som har E30 kunne plukket opp reléene sine og sjekket hva det sto på dem, slik at det blir helt riktig her, hadde jeg blitt veldig takknemlig!
Trenger bare å vite plasseringene fra K1-K8.
Pedi:
Er vell samme på min e30? Isåfall kan jeg gå ut å sjekke :)
Begynner å dra seg til føler jeg :)
Nå er det egentlig bare å få start og så få lufta bremser og clutch, så er vel bilen klar for prøvetur igrunn. :)
Synd jeg ikke får lakkert resten før til våren igjen, men men :)
Da har jeg vært ute å sedd i min e30. Ser jeg mangler k1, k5 og k8. Disse har jeg kjørt uten hele tiden, så veit ikke hva dem er til!
Det som står på k2,k3,k5 og k7 er:
601.484
61.31
1375474
k2,k3,k5 og k7 er orange
K4 er svart!
K4 har beskrevet 30 85 86 87 87B
Håper det var til noe hjelp. :)
Da var alle reléene på riktig plass! Kanonbra, takk for hjelpa Martin! :D
Venter bare på at typen til mamma skal komme innom med en skikkelig batterilader, en C-Tek sak.
Så er det bare å lade batteriet, koble til og vri om å se om starteren går!
Hvis ikke, må jeg feilsøke. Håper jeg slipper det! :)
Hvis den går, er det vel bare å fylle bensin og vann, og starte opp? ;)
har en Ctek permanent tilkobla i bilen jeg, funker gull :) Må bli sånn med eberspächer hver morgen, og bare 5 min å kjøre til jobb! :D
Flott Lars :) Hvis du plages med ledningene, kan jeg hjelpe deg. Har koblet e30 nettet flere ganger nå, så bare si ifra hvis det er noe ;) Husk at TPS og tomgangsregulator har samme kontakt, å man kan sette dem på feil plass. så hvis den går dårlig på tomgang, kan du prøve å bytte dem om :)
