Tronstad Skrevet Juli 13, 2012 Share Skrevet Juli 13, 2012 All ET/OFFSET is still dependent on tyre and wheel size so bear this in mind if you are trying to fit wheels from one model to a different model, also if the car is lowered then you may have issues with rubbing/non fitment due to fouling. The higher the ET number the more the wheel will sit inside the wheel arch 1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45 3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20 3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35 3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30 3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47 3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47 3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47 3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27, 3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45 3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37 5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25 5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20 5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. 5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25 5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25 5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32 5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32 5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32 6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. 6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20 6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20 7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26 7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25 7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 10-25 8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45 X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45 X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53 X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread. Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40 Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52 Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. Lenke til kommentar Del på andre sider More sharing options...
dutten Skrevet Juli 13, 2012 Share Skrevet Juli 13, 2012 hvilke et som passer vil og også endre seg litt etter bredden på felgen sant? Lenke til kommentar Del på andre sider More sharing options...
Tronstad Skrevet Juli 13, 2012 Forfatter Share Skrevet Juli 13, 2012 det avhenger selvfølgelig på bredden du velger på felg og dekk ja, oppdatert Lenke til kommentar Del på andre sider More sharing options...
haakon85 Skrevet Juli 13, 2012 Share Skrevet Juli 13, 2012 Bare for å pirke litt. E39 M5 har samme navdiameter som en vanlig E39, dvs. 74,1mm. Lenke til kommentar Del på andre sider More sharing options...
egil s Skrevet Juli 21, 2012 Share Skrevet Juli 21, 2012 E31 har 15mm på 7,5" felg, og ved alternativ 8"/9" felger 10/19mm. Lenke til kommentar Del på andre sider More sharing options...
Frode D Skrevet Juli 21, 2012 Share Skrevet Juli 21, 2012 ET er et forholdstall (millimeter) fra senter av felgen, den flaten som blir skrudd inn mot navet på bilen. På en 8" brei felg med ET 0, vil felgen bygge 10.16cm (4") utover og 10.16cm (4") innover. På en 8" brei felg med ET 20, vil felgen bygge 8.16cm utover og 12.16cm innover. osv..... Lenke til kommentar Del på andre sider More sharing options...
Mikael-B Skrevet Juli 21, 2012 Share Skrevet Juli 21, 2012 ET er et forholdstall (millimeter) fra senter av felgen, den flaten som blir skrudd inn mot navet på bilen. På en 8" brei felg med ET 0, vil felgen bygge 10.16mm (4") utover og 10.16mm (4") innover. På en 8" brei felg med ET 20, vil felgen bygge 8.16mm utover og 12.16 innover. osv..... Her mener du vel centimeter (10,16cm = 4" ) Lenke til kommentar Del på andre sider More sharing options...
egil s Skrevet Juli 22, 2012 Share Skrevet Juli 22, 2012 Han gjøre nok det ja. Innpress trenger ikke nødvendigvis å endres ved å gå opp i felgstørrelse, men dersom man ønsker en spesiell effekt, f.eks å fylle ut hjulhuset bedre, så kan man gå ned på innpresset for å flytte felgen ut og opp på innpresset for å flytte felger inn. som et eksempel. Du har en 8,5" felg med 35mm innpress, ved å senke innpresset til 25mm vil du flytte felgen utover, ved å øke innpresset til 45mm vil fu flytte felgen innover. Spacere vil føre til at innpresset bli LAVERE. Lenke til kommentar Del på andre sider More sharing options...
Frode D Skrevet Juli 23, 2012 Share Skrevet Juli 23, 2012 ET er et forholdstall (millimeter) fra senter av felgen, den flaten som blir skrudd inn mot navet på bilen. På en 8" brei felg med ET 0, vil felgen bygge 10.16mm (4") utover og 10.16mm (4") innover. På en 8" brei felg med ET 20, vil felgen bygge 8.16mm utover og 12.16 innover. osv..... Her mener du vel centimeter (10,16cm = 4" ) Selvfølgelig.. Skal rette opp feilen! Edit: Denne siden er fin til å finne ut hvor mye/mindre felger med annet innpress vil bygge innover og utover i forhold til originalt: http://www.willtheyfit.com/ Lenke til kommentar Del på andre sider More sharing options...
