Momentnøkkel fra Biltema, er det bra?
Need a torque wrench for working on my 328i engine, which must go down to a low enough range (for example the nuts of the valve covergasket need 89 inches-pound/10Nm).With a small kid, I don't have too much time to play around with the car, so it's gonna be only for the occasional easy job, so don't need the super pro heavy duty tool which costs a fortune..
Saw this in Biltema http://www.biltema.no/no/Verktoy/Handverktoy/Pipe--og-Nokkelverktoy/Momentnokler/Momentnokkel-2000020911/ - has anyone experience with it? It's 4-20Nm so would work.
Or any other suggestion?
Takk!
They are good, where i work we only use biltemas torque wrench, we also calibrate them every year and they are accurate, remember to set it at 0nm when you're done with it.
I have a torque wrench from biltema, and have been using it at least 6-7 years without any problem. Its not the model you are considering, but at bigger one  (up to 250nm I think). I also have a small one, but that one is from summitracing.com, I dont use the small wrench that much. 4-20nm is hand tight, and that is good engouth for me.
My biltema torque wrench is also calibrated professionally. ( my workplace delivers tools to the offshore buisness, and we have the  tools needed to calibrate the torque wrench) So the wrench is probably more accurate now, then when it was new :-D.
