  • Svar 40
Hei!
Står det på utstyrslisten at du har 0980 Exclusive pakke?
Kan være regnsensoren følger med der i så fall. :-)
Close Vehicle information
Type
Value
VIN WBADD11060BN53473
Type code DD11
Type 520I (EUR)
E series E39 ()
Series 5
Type LIM
Steering LL
Doors 4
Engine M52
Displacement 2.00
Power 110
Drive HECK
Transmission MECH
Colour ARKTISSILBER METALLIC (309)
Upholstery STOFF FLOCK STREIFEN/ANTHRAZIT (D3AT)
Prod.date 1997-12-12
Close Options
Code
Description (interface)
Description (EPC)
S266A LT/ALY WHEELS RADIAL SPOKE 48 BMW light alloy wheel, radial spoke 48
S302A ALARM SYSTEM Alarm system
S320A MODEL DESIGNATION, DELETION Deleted, model lettering
S428A WARNING TRIANGLE Warning triangle and first aid kit
S438A WOOD TRIM Fine wood trim
S441A SMOKERS PACKAGE Smoker package
S464A SKIBAG Ski bag
S494A SEAT HEATING F DRIVER/FRONT PASSENGER Seat heating driver/passenger
S500A HEADLIGHT WASHER SYS/INTENSIVE CLEANING Headlight wipe/wash/Intensive cleaning
S520A FOGLIGHTS Fog lights
S522A XENON LIGHT Xenon Light
S534A AUTOMATIC AIR CONDITIONING Automatic air conditioning
S540A CRUISE CONTROL Cruise control
S666A RADIO BMW BUSINESS CD Radio BMW Business CD RDS
S694A PREPARATION FOR CD CHANGER Provisions for BMW 6 CD changer
Code
Description (EPC)
S842A COLD CLIMATE VERSION Cold-climate version
S863A EUROPE/DEALER DIRECTORY Retailer Directory Europe
S888A DANISH/OWNERS HANDBOOK/SERVICE BOOKLET Operating instructions, Danish
S896A DAYTIME LIGHTS FUNCTION Daytime driving light switch
S925A SHIPPING PROTECTION PACKAGE Transport protection package
Close Standard equipment
Code
Description (EPC)
S260A SIDE AIRBAG DRIVER/FRT PASSENGER Side airbag for driver/passenger
S411A WINDOW LIFTS, ELECTRIC Window lifts,electric,front/rear
S548A SPEEDOMETER WITH KILOMETER READING Kilometer-calibrated speedometer
S550A ON-BOARD COMPUTER On-board computer
Ser ikke noe Exclusive pakke her.
Står ikke noe om hverken det ene eller det andre i spec`en til min bil heller.. men har det. Sett viskerinstillingen på første hakket og sprut litt vann øverst på midten av frontruta. Viskerne skal da gå når det er noe som havner i dette feltet som er dekket av denne svarte boksen din... Med mindre den er ødelagt.
Virker som mine går på vanlig intervall. Har ikke under søkt noe særlig om regnsensoren. Når jeg setter den opp et hakk, går den en gang. Og så virker det som om den går på intervall, selv om det regner. Kan det ligge en feilkode eller sikring som er røket som gjør at den ikke fungerer?
Regnsensor må læres opp... Slå den av, neste gang det kommer vann på ruta som gjør at du må bruke viskern så skrur du på regnsensoren.. Denne lærer da at når det kommer vann på ruta som tilsvarer samme mengde eller mer, så skal den skrues på...
Regnsensor kan ha en tendens til å miste funksjonen og må resettes. Dette gjøres enklest ved å kople fra batteriet i 30min.
Hvis du har en sort klump som er limt fast i ruta så er det regnsensor.
Sort klump rett bak speilet, som har en linse i midten med noe blått i :)
Skal prøve det med batteriet på søndag, skal på jobb i dag så får ta det i morgen.
Du har regnsensor hvis du ser blå/grønn lignende linse.
Sett den på første hakk opp, ta et glass vann og hell over linsen, altså på ruta. Da får du svaret om det funker eller ikke. Eller om du har regnsensor:P
God helg!
Prøvde og resette regnsensoren med å koble fra batteriet i 30 min uten noe resultat. Har lest litt rundt om at det kan være releet som kan være gåent. Skal få tak i et nytt releet straks bare får å prøve. Hvis ikke kan det hende at jeg må bytte selve regnsensoren.
Har lest litt rundt på forskjellige forum, og da virker det som at min regnsensoren går i en slags nødmodus. Noen som har noe forslag?
Det skal nevnes at man ikke trenger å helle vann foran sensoren, altså midt på, øverst på ruta.
Regnsensoren fungerer ved at boksen bak speilet sender et IR-lys utover frontruten, og en mottaker midt på dashen, gjemt i luftekanalen måler hva den får. Differansen mellom sendt og mottatt signal sendes så til hjernen, og den ser hvilken sensitivitet som er satt inn på intervallen, og finner ut om den skal ta et sveip over ruta :)
Så det er det den lille kladden er til... den kan jo sikkert feile om den er møkkete el no..
Stemmer! Jeg lurte veldig på hva den lille boksen nede ved ruta var, og min var heller ikke presset ned slik den skal da jeg kjøpte bilen. Tok meg fire uker før jeg skjønte at den skulle sitte skjult nede i luftekanalen...
Har vært innom Østbyen bil (BMW forhandler i Bodø) og snakka med dem om regnsensoren. De mente at jeg måtte re-programmere regnsensoren eller bytte noe i selve sensoren (linser eller hoder, husker ikke helt hva de kalte dem).
Har ikke lyst å bruke så mye penger på dette, så jeg lurer på om noen har en ide om hva jeg kan gjøre?
