niets Skrevet Januar 8 Share Skrevet Januar 8 (endret) Hei, Gjelder bil: 1 serie 116i 2013 med automatkasse. Jeg har følgede spørsmål: Kan automatkassa (i sportsmodus/spak vippet til venstre) lære av kjøremønsteret til sjåføren når han velger å gire manuelt? Endret Januar 8 av niets Lenke til kommentar Del på andre sider More sharing options...
Otis Skrevet Januar 8 Share Skrevet Januar 8 Kort svar, nei. Langt svar: Driver type adaptation The following information is processed for adaptation purposes: Fast depressing of the accelerator pedal Rapid retraction of the accelerator pedal Corner assessment Brake evaluation Assessment when driving at a constant speed Adaptation assesses the longitudinal and transverse dynamics from the following operating elements with relation to the driving speed: Accelerator pedal Brake Steering These values result in the current driving condition and the driver's desired load. This is the basis to determine the driver's performance request and the current driving condition. The demand for higher dynamics is detected on the basis of these values. Driver type adaptation offers a temporary adaptation of the basic map. To be able to achieve consumption and comfort targets, the system selects defensive shift characteristics in driving situations without a specific performance request. The assumption applies that the vehicle should be in the highest possible gear and only shift down if power output is requested and the engine is already supplying full torque. Downshift threshold values are distributed across the range of the accelerator pedal so that fully depressing the pedal triggers a downshift of several gears. Due to the fact that smooth gear change setup is not ideal in every situation, the current driving situation is automatically determined and taken into account as a driving operation assessment. ///M-ini95 reagerte på dette 1 Lenke til kommentar Del på andre sider More sharing options...
niets Skrevet Januar 8 Forfatter Share Skrevet Januar 8 Tja....det er vel ikke gitt at svaret er "nei"? Etter beskrivelsen tar BMW-systemet hensyn til hvordan sjåføren bruker gasspedal, bremser og styring. Samtidig ønsker systemet å optimalisere drivstoffeffektiviteten og kjørekomforten. Et raskere girskift samt å holde et høyere gir i konstant hastighet vil jo fremme disse formålene. Dette vil vel da kunne læres hvis sjåføren tilstreber en slik kjørestil i manuell modus? Lenke til kommentar Del på andre sider More sharing options...
Otis Skrevet Januar 8 Share Skrevet Januar 8 Det er kanskje sant, jeg bare antok at "sport" ikke ble omfattet av "D" modus, men jeg kan ta feil. Lenke til kommentar Del på andre sider More sharing options...
niets Skrevet Januar 9 Forfatter Share Skrevet Januar 9 Ok. Takker for svar. Jeg vet jo ikke. Fikk råd om å ta spørsmålet opp med noen som kjenner systemet. Tenkte kanskje noen her inne satt med svaret. Lenke til kommentar Del på andre sider More sharing options...
