  • Svar 177
  • 3 months later...
Ja det må jeg snart gjøre! Tror bilen må nedregges til 2seter med den vekten den legger på seg nå om dagen! ;)
Litt specs på Kicker Solo X 18" kan nevne at den veier 50kg..
http://www.kicker.com/sites/default/fil ... %20Web.pdf
Model S18X
Size (IN., CM) 18, 45.7
Impedance (OHMS) 1 ohm DVC or 2 ohms DVC
Max Rec Amplifier Power (WATTS PEAK) 10000
Max Rec Amplifier Power (WATTS RMS) 5000
Sensitivity (dB 1W/1M) 89.7
Frequency Response (HZ) 18-100
Mounting Depth (IN., CM) 11-3/8, 28.9
Mounting Cutout, Square (IN., CM) 16-11/16, 42.4
Recommended Box Volumes The SoloX is engineered for highly specialized installations/applications. See the Tech Manual or consult the KICKER Technical Support Team for enclosure specifications based on your individual requirements.
